OSTC2: New 2.90 firmware
Re: OSTC2: New 2.90 firmware
Post by scubatinoo »
Have a look here:
file.php?2,file=448,filename=Custom_Functions_V2_70.pdf
Your first adress for documentation is www.heinrichsweikamp.com
dandipdive Wrote:
> CF57!
> CF56!
> what does this means?
CF56 and CF57 are not within their recommended boundaries.
Reset them in the CFII menu.
Arctic Diver
Post by Arctic Diver »
Just did the update from V2.50 to 2.90.
Installation went well. No Probs. 55 sec - done.
Then I tried the new firmware in German (my native language) - but I didn't like it and changed back to english.
So, let's rock'n'roll with V2.90 :D
OSTC 4914 V2.50
Frappawotsit
Post by Frappawotsit »
My Update to V2.90 via a MAC and using JDivelog to complete the upgrade went smoothly..... new firmware ready to dive!
After 3x Failed OSTC3's... I finally settled for an OSTC2c (#7138).... So far, so good!!!!
Tecchiegirl
Post by Tecchiegirl »
Upgrade went smoothly. Unfortunately it wiped out my logbook! Any way I can retrieve this please?
I can't see why an upgrade should influence the logbook data. From which version did you upgrade to the 2.9 and which update tool did you use?
moki82
Post by moki82 »
there is Italian translation for firmware 2.90?
nodekh
Post by nodekh »
Hi.
After upgrading from 2.21 to 2.90 every CF higher than 73 is set to 255 and the unit indicates that default is 0. Should I change every to 0?
Another thing is that I can not switch CF69 to off.
OSTC 2N 4689
Continue here: read.php?2,14038
