Today, the new 1.54 beta firmware for the OSTC3 has been released: http://www.heinrichsweikamp.com/?id=162&version=en
Getting ready for the new stable...
New since 1.50:
BUGFIX: Clear Setpoint-Fallback warning when in bailout
NEW: 180° display rotation option
NEW: Show ppO2 for change depth during gas setup
CHANGE: Re-arranged Settings Menu
BUGFIX: PC configuration issues fixed
NEW: Safe tissue data, date and time during firmware update
CHANGE: Postion of min. and (NEW: ) max. temperature in logbook
BUGFIX: Fast diluent (w/o dive mode menu) change did not work correctly
BUGFIX: Flip compass with flipped screen, too
BUGFIX: Surface interval was paused during simulator
BUGFIX: False max. temp in Logbook, false Bailout and Gas 6 flags in logbook
CHANGE: Improve internal logbook usability
CHANGE: Compass readout smoothed
BUGFIX: Future TTS in sensor mode (CCR Mode)
CHANGE: Clarify Travel Gases with "---" as change depth
CHANGE: Enable "Change Depth" Menu only for deco gases
CHANGE: Draw a frame around the dive mode menu
BUGFIX: Average depth computation
Please install the firmware using the "OSTC Companion" software.
Heute haben wir die neue OSTC3 Firmware v1.54 beta veröffentlicht: http://www.heinrichsweikamp.com/?id=162&version=de
Wird also langsam Zeit für eine neue Stable...
Neu seit der 1.50:
Bitte die Firmware mit dem "OSTC Companion" Programm installieren.
New 1.54 beta firmware
Re: New 1.54 beta firmware
Here are some screenshots from the 1.54beta:
Surface mode:
[img]file.php?6,file=622,filename=surf.png[/img]
OC Gas Setup:
[img]file.php?6,file=621,filename=gas_setup.png[/img]
Divemode (OC Gas List):
[img]file.php?6,file=620,filename=oc_gas_list.png[/img]
Divemode menu:
[img]file.php?6,file=619,filename=divemode_menu.png[/img]
Gas1: 21/20 First Gas
Gas2: 10/70 Travel Gas
Gas3: 50/20@22m Deco Gas 1
Gas4: O2@6m Deco Gas 2
Gas5: NX32 Disabled
Surface mode:
OC Gas Setup:
Divemode menu:
Gas5: NX32 Disabled
- ClaudeDive
Re: New 1.54 beta firmware - Bug Gas 6 in simulator
[left][/left]
Test with simulator:
[left][/left]
I setup the Gases list: Gas 1 * Air (First Gas) and Gas 2: Tx 14/50 (Gas Disabled)
[left][/left]
I open the simulator with 64 m > Gas 1: * Air (First Gas) - The Calculation is correct "EAD"=64m and "END"=64m
[left][/left]
I change the gas and setup with: Gas 6 Tx 14/50 and I have the screen below :
[left][/left]
[img]file.php?6,file=631,filename=IMAG0736.jpg[/img]
[left][/left]
The value "EAD" is false, OSTC3 has retained the previous value "EAD", the value Air in this eg, when installing the gas 6
[left][/left]
I again changed the Gas and setup with: Gas 2 Tx 14/50 and I have the screen below,
[left][/left]
[img]file.php?6,file=632,filename=IMAG0737.jpg[/img]
[left][/left]
The Calculation "EAD" is correct, OSTC3 to recalculated the "EAD" with good value, the calculation is OK for the gases installed,
[left][/left]
When correcting this bug, it would be very interesting, as I requested in another topic, to replace the display "EAD / END" with "EAD / MOD like on OSTC Sport:
[left][/left]
[img]file.php?6,file=633,filename=IMAG0737a.jpg[/img]
[left][/left]
or better substitute by pO2 Max / MOD (Values of the gas in use)
[left][/left]
[left][/left]
The "EAD / END" values are of no use during the dive, but only useful when planning the dive,
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
Thanks. Fixed in the next release.
I disagree, for me MOD is for planning and END/EAD give interesting informations during the dive. Especially when using two (or more) different trimix gases during one dive.
This is unlikely to be changed, sorry.
- ClaudeDive
Matthias Wrote:
[left][/left]
I disagree, for me "MOD" is for planning and "EAD / END" give interesting informations during the dive. Especially when using two (or more) different trimix gases during one dive.
[left][/left]
[left][/left]
Of course "MOD", "EAD", "END" are essential for planning your dive ...
[left][/left]
- But after planning your diving on the dry ground taking into account the parameters above and problems of against diffussion-gases ...
[left][/left]
- Once in the water, how you use and what action can you have on the parameters "EAD" & "END"?
[left][/left]
- While during your dive, the parameters "pO2 Max" & "MOD" of the gas in use are recall of Maxi to not exceed that you can control depending to your current depth throughout your dive and your decompression,
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
I see your point but do now please accept that is won't be changed.
- ClaudeDive
Without your explanations it difficult for users to understand your point of view but it's you the designer,
[left][/left]
Thank you anyway for your reply,
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
