New 1.54 beta firmware
Today, the new 1.54 beta firmware for the OSTC3 has been released: http://www.heinrichsweikamp.com/?id=162&version=en
Getting ready for the new stable...
New since 1.50:
BUGFIX: Clear Setpoint-Fallback warning when in bailout
NEW: 180° display rotation option
NEW: Show ppO2 for change depth during gas setup
CHANGE: Re-arranged Settings Menu
BUGFIX: PC configuration issues fixed
NEW: Safe tissue data, date and time during firmware update
CHANGE: Postion of min. and (NEW: ) max. temperature in logbook
BUGFIX: Fast diluent (w/o dive mode menu) change did not work correctly
BUGFIX: Flip compass with flipped screen, too
BUGFIX: Surface interval was paused during simulator
BUGFIX: False max. temp in Logbook, false Bailout and Gas 6 flags in logbook
CHANGE: Improve internal logbook usability
CHANGE: Compass readout smoothed
BUGFIX: Future TTS in sensor mode (CCR Mode)
CHANGE: Clarify Travel Gases with "---" as change depth
CHANGE: Enable "Change Depth" Menu only for deco gases
CHANGE: Draw a frame around the dive mode menu
BUGFIX: Average depth computation
Please install the firmware using the "OSTC Companion" software.
Heute haben wir die neue OSTC3 Firmware v1.54 beta veröffentlicht: http://www.heinrichsweikamp.com/?id=162&version=de
Wird also langsam Zeit für eine neue Stable...
Neu seit der 1.50:
Bitte die Firmware mit dem "OSTC Companion" Programm installieren.
Re: New 1.54 beta firmware
Here are some screenshots from the 1.54beta:
Surface mode:
[img]file.php?6,file=622,filename=surf.png[/img]
OC Gas Setup:
[img]file.php?6,file=621,filename=gas_setup.png[/img]
Divemode (OC Gas List):
[img]file.php?6,file=620,filename=oc_gas_list.png[/img]
Divemode menu:
[img]file.php?6,file=619,filename=divemode_menu.png[/img]
Gas1: 21/20 First Gas
Gas2: 10/70 Travel Gas
Gas3: 50/20@22m Deco Gas 1
Gas4: O2@6m Deco Gas 2
Gas5: NX32 Disabled
ClaudeDive
Re: New 1.54 beta firmware - Bug Gas 6 in simulator
Post by ClaudeDive »
[left][/left]
Test with simulator:
[left][/left]
I setup the Gases list: Gas 1 * Air (First Gas) and Gas 2: Tx 14/50 (Gas Disabled)
[left][/left]
I open the simulator with 64 m > Gas 1: * Air (First Gas) - The Calculation is correct "EAD"=64m and "END"=64m
[left][/left]
I change the gas and setup with: Gas 6 Tx 14/50 and I have the screen below :
[left][/left]
[img]file.php?6,file=631,filename=IMAG0736.jpg[/img]
[left][/left]
The value "EAD" is false, OSTC3 has retained the previous value "EAD", the value Air in this eg, when installing the gas 6
[left][/left]
I again changed the Gas and setup with: Gas 2 Tx 14/50 and I have the screen below,
[left][/left]
[img]file.php?6,file=632,filename=IMAG0737.jpg[/img]
[left][/left]
The Calculation "EAD" is correct, OSTC3 to recalculated the "EAD" with good value, the calculation is OK for the gases installed,
[left][/left]
When correcting this bug, it would be very interesting, as I requested in another topic, to replace the display "EAD / END" with "EAD / MOD like on OSTC Sport:
[left][/left]
[img]file.php?6,file=633,filename=IMAG0737a.jpg[/img]
[left][/left]
or better substitute by pO2 Max / MOD (Values of the gas in use)
[left][/left]
[left][/left]
The "EAD / END" values are of no use during the dive, but only useful when planning the dive,
[left][/left]
[left][/left]
Cheers ;)
Thanks. Fixed in the next release.
I disagree, for me MOD is for planning and END/EAD give interesting informations during the dive. Especially when using two (or more) different trimix gases during one dive.
This is unlikely to be changed, sorry.
ClaudeDive
Matthias Wrote:
[left][/left]
I disagree, for me "MOD" is for planning and "EAD / END" give interesting informations during the dive. Especially when using two (or more) different trimix gases during one dive.
[left][/left]
[left][/left]
Of course "MOD", "EAD", "END" are essential for planning your dive ...
[left][/left]
- But after planning your diving on the dry ground taking into account the parameters above and problems of against diffussion-gases ...
[left][/left]
- Once in the water, how you use and what action can you have on the parameters "EAD" & "END"?
[left][/left]
- While during your dive, the parameters "pO2 Max" & "MOD" of the gas in use are recall of Maxi to not exceed that you can control depending to your current depth throughout your dive and your decompression,
[left][/left]
[left][/left]
Cheers ;)
I see your point but do now please accept that is won't be changed.
ClaudeDive
Without your explanations it difficult for users to understand your point of view but it's you the designer,
[left][/left]
Thank you anyway for your reply,
[left][/left]
[left][/left]
Cheers ;)
