Inactive Gas
Jean-François
Inactive Gas
Post by Jean-François »
Hello peeps,
I have a question about the active/inactive gases.
When configuring my gases, sometimes they turn to the inactive color but if I go to the specific gas "More" menu it still states that the gas is active.
It usually happens when I change the first gas. My last first gas goes into the state described above.
So is the gas active or not ? and why does it shows in the inactive color.
OSTC Mk2N 2287
Bardass
Re: Inactive Gas
Post by Bardass »
parce que la profondeur de ce gaz est à 0m, ce qui le rend inactif même si son statut est actif
because depth is set to 0m. So your gaz is inactive even if its statut is active
Bardass
Jean-François
Re: Inactive Gas
Merci Bardass
Comme c'est inscrit actif mais que la couleur est inactif, est-ce qu'il est actif ou pas ?
Thanks Bardass
Since the active gas is ticked but the gas is in the inactive color, is the gas active or not ?
OSTC Mk2N 2287
jb2cool
Re: Inactive Gas
Post by jb2cool »
You are able to manually switch to this gas and deco will be recalculated to reflect this. It is currently not being taken into account with deco calculations.
Bardass
Re: Inactive Gas
Post by Bardass »
on se fiche qu'il soit actif ou pas : tu peux activer ou désactiver un gaz sous l'eau
le seul impact porte sur la DTR qui ne tient pas compte de ce gaz actif utilisable à 0m.
Car ce gaz est déclaré comme inutilisable avant de rejoindre la surface.
we don't care that this gas is active or not: you can enable or disable a gas under water
the only impact is on TTS : TTS ignores this active gas used at 0m.
Because this gas is declared unusable before reaching the surface.
Bardass
Jean-François
Re: Inactive Gas
Merci
OSTC Mk2N 2287
