Hello peeps,
I have a question about the active/inactive gases.
When configuring my gases, sometimes they turn to the inactive color but if I go to the specific gas "More" menu it still states that the gas is active.
It usually happens when I change the first gas. My last first gas goes into the state described above.
So is the gas active or not ? and why does it shows in the inactive color.
Inactive Gas
Re: Inactive Gas
parce que la profondeur de ce gaz est à 0m, ce qui le rend inactif même si son statut est actif
because depth is set to 0m. So your gaz is inactive even if its statut is active
Jean-François
Re: Inactive Gas
Merci Bardass
Comme c'est inscrit actif mais que la couleur est inactif, est-ce qu'il est actif ou pas ?
Thanks Bardass
Since the active gas is ticked but the gas is in the inactive color, is the gas active or not ?
Thanks Bardass
OSTC Mk2N 2287
jb2cool
Re: Inactive Gas
You are able to manually switch to this gas and deco will be recalculated to reflect this. It is currently not being taken into account with deco calculations.
Re: Inactive Gas
on se fiche qu'il soit actif ou pas : tu peux activer ou désactiver un gaz sous l'eau
le seul impact porte sur la DTR qui ne tient pas compte de ce gaz actif utilisable à 0m.
Car ce gaz est déclaré comme inutilisable avant de rejoindre la surface.
we don't care that this gas is active or not: you can enable or disable a gas under water
the only impact is on TTS : TTS ignores this active gas used at 0m.
Because this gas is declared unusable before reaching the surface.
