PC Simulation to match?
Turtle
Post by Turtle »
I am familiar with Vplanner software and use it occasionally, if I am going to use custom backup tables with my OSTC.
Is there similar planning software available to match the OSTC's model, including using GFs? (and print out tables to match the GFs?)
Nige
UK. Recreational Diver
- Turtle
Recreational User/Tester
UK
Hiasl
Re: PC Simulation to match?
Post by Hiasl »
I tried GAP, which features the same model (ZH-L 16C with GF) like the OSTC and that worked on "dry runs" ;-)
I did no in-water-testing.
OSTC Mk II #661
Bradipo
Post by Bradipo »
I use GAP too for planning.
There are other options which use Buhlmann with GF, but GAP is the most reliable I have found so far (in the sense that the other programs that I have tried often crash or do not run on my pc).
I also have a freeware version of JDeco which runs on mobile phones and Blackberrys. It also supports Buhlmann+GF, but it has many limitations, unless you pay for the full version. Price is similar to that of GAP in its cheapest flavour, i.e. OC and nitrox only (~40-50 EUR)
Turtle
Post by Turtle »
Thanks guys, will download a trial of GAP and have a play.
- Nige.
- Turtle
UK
Marou
Post by Marou »
I use MV-PLAN 1.5
It's a free software. Works for OC and CC
Antoine
Post by Antoine »
And Mv-plan as the same feature than the OSTC, no more than 100 m.
Based on the same deco algorythm, http://damiensiviero.com/Diving.aspx
Turtle
Post by Turtle »
thanks, will also have a look at MV-plan
- Turtle
UK
Nordicdive.de
Post by Nordicdive.de »
I use WINGUI, I don't know if this SW is available in English.
The WINGUI are working with ZHL 16c or ZHL 16b.
kurt.sys
Post by kurt.sys »
I use MV-plan too, and recently I asked them to implement the factor for faster compression and slower decompression too (as it is with the ostc). It seems Guy Wittig is willingly to add that feature, which would match the model used in the ostc... Only one question: for ascending and descending parts of the profile, suppose the ostc is programmed as follows (mainly the place where the 'factor' is used is important here) - I still have to answer that to Guy Wittig, so he can implement it in mv-plan in one way or another:
deltaP = (Pio+R(t -1/k)-[Pio-Po-(R/k)]e^-kt) - Po
P = Po + factor * deltaP
Besides this, one more question, just to be sure: if the ostc is set to use the L16-GF algorithm (instead of ZH-L16), the factors for faster compression/slower decompression still apply, don't they?
Kurt
fin
Post by fin »
onestop
is also a good alternative
Leave bubbles behind (not up)
