I dive with my wife using a MARES NEMO WIDE.
What settings do you recommend for fairly similar decompression?
OSTC Sport MARES NEMO WIDE
Re: OSTC Sport MARES NEMO WIDE
this question is better asked to Mares - because the OSTCs are open source computers - it is clear what OSTC does ... but Mares???
anyway i dive normaly GF 40/80 and my friend uses a Mares Icon HD black edition (i do hate this display layout) and we usually have about the same TTS on regular air dives to app. 45m
Thank you
which decompression model?
Motardplongeur
Hi
Some information after 4 dives (Marseille, last week end) with my Sport (10.19) and a Nemo Wide (first model, last software "3 gases") :
All dives in two days, from 45 to 62 mn, temperature between 18°C & 15°C, max depth from 30 to 36 m, average depth between 17 & 22 m ; air.
Nemo Wide at the lowest level of conservatism.
Sport with Bülhmann (w/o GF) and last deco 4 m
2 dives made with "conservatism +0" (112/88 %):
=> max deco displayed on the NW : 7 mn
=> max deco displayed on Sport : 3 mn
Real deco : 2 mn on Sport & 7 on NW (not "real" time but displayed time at 4 m ; i did not check real time, knowing deco at 4 m for NM gives (very) longer minuts !)
2 dives made with "conservatism +1" (115/85 %) :
=> max deco displayed on Sport : 6 mn
Real deco : 4 mn on Sport & 5 on NW (same remarks as above)
2 buddies with Suunto Stinger or Vyper : deco duration + 5 ou 6 mn compared to Sport.
I'll try to show curves time/depth/deco while free time.
[EDIT] : Sport's conservatism modified, sorry I made a mistake
OSTC #12002 & #11150
Motardplongeur
Hi
After 5 new dives (Cavalairen this WE) between 32 & 52 m (45 to 25 mn, 20°C), I confirm that "+1 conservatism" (115/85 %) on the Sport gives approx same results as my Nemo Wide from a deco point of vue.
