V1.40 Stable
V1.40 Stable
The new stable 1.40 is now available for download!
Die Stabile version 1.40 ist nun verfügbar!
Viele Grüsse/Regards,
diego
Re: V1.40 Stable
Post by diego »
Ciao
Sorry for my english,but where is the new stable 1.40 for download?
saluti
Diego
Re: V1.40 Stable
Get the file here: V1.40 Stable
Jostein
Re: V1.40 Stable
Post by Jostein »
Vielen Dank für die neue Version! Wird gleich mal ausprobiert.
Jostein
Anonymous User
Re: V1.40 Stable
Post by Anonymous User »
diego Wrote:
> Ciao
> 1.40 for download?
> saluti
> Diego
I download the .zip file in the link and extract it and I get a file without hex extensions.
Same for bootloader in the download section.
Neither file works when adding the missing .hex extension or missing .exe extension.
Something wrong either at my end or your end!
Re: V1.40 Stable
Hallo, bei mir gehts auch nicht, Gruss, Reiner
pem
Re: V1.40 Stable
Post by pem »
Hello,does this version have the ave depth and stopwatch i enquired about on a previous occasion? thanks,simon.
pem
Re: V1.40 Stable
Post by pem »
i HAVE ALSO NOT BEEN ABLE TO EXTRACT ANYTHING FROM THE ZIP FILE
Anonymous User
Re: V1.40 Stable
Works now.
Flashing and will test dive tomorrow.
Have the problems with deco on CCR been fixed on this version?
andersnasman
Re: V1.40 Stable
Post by andersnasman »
Sorry, I cannot open the ZIP archive either...
Re: V1.40 Stable
Works fine here - it was packed just as all the other releases. As usual, it contains the HEX and two text files.
Re: V1.40 Stable
> thanks,simon.
Average depth is included and tested in all modes. Stopwatch is also in the code but is not displayed yet. I was unsure where to put it on the screen.
Re: V1.40 Stable
> this version?
There are no known deco issues in this version. We have tested this version intensively.
corona_citron
Re: V1.40 Stable
Post by corona_citron »
CCR dive - 57m 70 minutes.... no problems
andersnasman
Re: V1.40 Stable
I succeeded in opening the archive with 7-zip however Windows filemanager complains about the zip file beeing broken or not valid.
I'll try th S/W this weekend.
Ferdy
Re: V1.40 Stable
Post by Ferdy »
Ich hatte unter Linux keinerlei Probleme mit dem .zip File. Und auch die .hex ließ sich problemlos installieren.
Andreas
pem
Re: V1.40 Stable
Post by pem »
heinrichsweikamp Wrote:
> Hello,
> two text files.
> regards,
Hello Matthias,could the stopwatch go under the current dive time in gauge mode and be started and reset with the select button? this would be really useful,thanks,simon.
divinglog
Re: V1.40 Stable
Post by divinglog »
No problems with the zip file using Winzip.
nicolas schreyer
Re: V1.40 Stable
Post by nicolas schreyer »
hello,
what is the difference between the 1.38 beta and the 1.40 stable ?
Anonymous User
Re: V1.40 Stable
First dive on 1.40 and it was nice.
The main problem encountered is the legibility of the smaller numbers (i.e. Setpoint, temperature, average depth).
They are all very legioble on the surface, but diving it is just number guessing. At leat the Setpoint has to be bigger (to make sure theright setpoint is selected).
Bear in mind I dive in caves (water is crisp clear), but with powerful lights in pitch darkness (and the water is clear long range, but short range there is some distortion when reading small numbers nearby) and this is where I find the problem.
Probably down to 100 meters (or past 70 meters) even in clear water one would have a similar problem.
Re: V1.40 Stable
still unable to download or unpack this file on two different computers with Vista and XP
no problem at all with 1.38 ! ! !
Re: V1.40 Stable
Hello Reiner,
This is direct link: code140.zip and (just in case) I have it attached to this post, too. I've tested this file with a number of zip tools on different computers and systems, so if it does not work at your place - try again in 24hours.
angelain
Re: V1.40 Stable
Post by angelain »
Matthias , don't know what is wrong, but I get this message from winzip(see attachment)
Alain Goemaere
Belgian
IANTD ADVANCED NITROX/PADI DM/CMAS 3*/CEDIP 4*
Re: V1.40 Stable
This is my fault-message.
I'll try again tomorrow.
Steve
Re: V1.40 Stable
Post by Steve »
no problems extracting the file
Steve
CMAS 2* Instructor
Belgium
