hwOS Tech: 2.15 released
The new hwOS Tech (for OSTC3, plus, cR and OSTC 2) firmware 2.15 is now available for download:
http://heinrichsweikamp.com/service/firmwares
The firmware itself can be set to English, Deutsch, Italiano and Français. The firmware is now split into two language versions: English + German and French + Italian. Make sure to install the correct HEX file.
Die Firmware selbst kann auf Englisch, Deutsch, Italienisch und Französisch gestellt werden. Die Firmware ist nun auf zwei Versionen geplittet (Englisch + Deutsch sowie Französisch und Italienisch), achtet darauf die richtige HEX Datei zu installieren.
Changes/Änderungen:
[2.15]
NEW: Deep Sleep mode for OSTC Plus and OSTC 2 (2017) (Entered automatically)
NEW: Logbook detail page in larger font (And nicer layout)
CHANGE: Sleep mode current slightly reduced for all hwOS devices
NEW: Logbook now records battery information
NEW: Markers in internal logbook drawn as small "m" next to the profile
[2.13]
BUGFIX: Layout fixes in Gauge mode (German and French language only)
[2.12]
CHANGE: Indicate "Bailout" for bailout deco plan in internal deco planer
CHANGE: Easier to understand "New Battery" menu (OSTC model dependent)
BUGFIX: Minor layout corrections in imperial units dive screen
NEW: New Customview 11 in dive mode shows ppO2, EAD/END and CNS
CHANGE: Customview 4 shows Clock, Battery Information and Tissue Information
CHANGE: Show warnings either in Customview (If active) _or_ next to warning sign
NEW: Show battery type in information menu (T0:3.6V AA, T1:1.5V AA, T2:3.6V/0.8A LiIon, T3:Internal 18650, T4:Internal 16650)
NEW: Show battery type in surface mode next to battery voltage
Details on hwOS: http://heinrichsweikamp.com/hw-os
Additional details on the new version can be found here: https://www.facebook.com/heinrichsweikamp/
Changes/Änderungen:
[2.15]
[2.13]
[2.12]
Re: hwOS Tech: 2.15 released
Installed easily using Subsurface. One thing, in the logbook, the dive number on mine is missing tiny bit of the bottom part of the number and it appears at the top above it instead.
Sydney
Australia
OSTC 2 11528
Sydney
Australia
OSTC 2 11528
Just noticed that this also happens on other pages, not only to the top entry. Bottom part of letters like g appear above the letter.
Sydney
Australia
OSTC 2 11528
Sydney
Australia
OSTC 2 11528
When re-entering the menu. Is the effect gone?
This is very strange! I have checked again now and it is not doing it. Everything seems perfect. Perhaps the computer needs to enter the deep sleep mode! Anyway, all okay now.
Sydney
Australia
OSTC 2 11528
Sydney
Australia
OSTC 2 11528
Hi Matthias, I just made the update to the new version 2.15 in my OSTC 2.
It has been perfectly upgraded, but I encounter a major problem: the sensitivity of the two buttons seems to have been placed on the less sensitive level. I can not access anything. My fingers already hurt, I hurt and I get nothing. Any solution?
> solution?
Even the hardest setting should be useable. One little trick you can try is to cool down the unit (freezer). Cold temperatures increase the sensitivity of the buttons a lot. Then choose a lower value, like 40% or less in the settings menu.
A reboot will also fix the settings: Place unit on charger and toggle a reset with a quite strong magnet in the center of the screen until the OSTC reboots. The magnet sensor will only reset the unit while charging.
> solution?
Hatte es nach einen Update ähnlich wie Maixi, habe den TC dann einfach eine weile liegen lassen bzw. am nächsten Tag noch einmal probiert und dann hat es wie immer sehr gut funktioniert.
VG
Caro
VG
Caro
Hi, Matthias,
The operation did not work yesterday through the freezer.
Actually, after the upgrade and after a lot of effort he could actually press the left button, entering the menu. But the right, impossible, so I can not make the selection. Cooling the computer, it has been the same.
I have to say that I had the computer configured with the left sensitive button, I think 30% and the right 40%
There is now the option to reset it. Please give me some more details on how to do it. I place it in the base of charge and pass a magnet on the screen. Nothing more?
And if this also fails, what can I do?
Thanks for your help.
Maixi
Maixi
Hi, Caro,
The German translator does not behave properly and I can not understand your message. Please, could you translate it into English?
Thank you!!
Maixi
Thank you!!
Maixi
Caro said:
I had the same issue like Maixi after an update. I just left the OSTC alone for a while and next morning I checked again and everything was fine like before.
Continue here: read.php?6,18215
