Mod for first gas is wrong
KEngelstoft
Post by KEngelstoft »
Hi, when editing a first/travel gas on OSTC3 the MOD is calculated based on ppO2 1.6 instead of 1.4 bar. This should only happen for deco gasses.
Best Regards,
Kasper
OSTC3 #576, replaced by OSTC3 #2827
Re: Mod for first gas is wrong
The hwOS currently uses only one max. ppO2 setting for all gases. And the default for this is 1.60bar.
meanwhile, there are two settings, a ppO2 bottom max and a deco max, which are used dependent on the gases configured as deco gas or something else (first, travel).
