strange Mk 2 problem
gordon mackie
I was diving today - fresh water ice dive - 4 degrees and 6m max...Mk2 just went blank after 10 mins and would not switch on...came home and plugged in to PC and got orange LED flashing single and double flash and "Building MD2 Hash please wait" every few minutes...today's dive not in log and date etc reset to factory defaults... reloaded 1.5 and it loaded OK but still get Orange LED flashing a pattern of single and double flashes and no red charge LED lit.
Any clues?
thanks - Gordon
Any clues?
thanks - Gordon
46 years diving! Must be Doing It Right :-)
Re: strange Mk 2 problem
Hi Gordon,
Check if the USB bulkhead is dry. Several errors are displayed with the red LED, if in error mode every 15s a series of led pulses is emitted.
gordon mackie
HI
that may be it..looks like there may be a drop of water...have left on its side to dry - thanks..will put a spot of silicon grease on the cap
gordon mackie
strange - now says "unexpected reset from dive mode! Please help and report the debug information below!
qfcebe. 4 255
0 0 4 2 128
0 0 0 208 0
and cannot switch on - orange light on solid and unit frozen
qfcebe. 4 255
0 0 4 2 128
0 0 0 208 0
Hi Gordon,
Press right button and the unit will start again from the debug screen.
gordon mackie
Hi Matthias
right and left buttons do nothing...solid orange light and completely locked up
Hello Gordon,
Is the debug screen still displayed?
gordon mackie
hi
completely blank..kept trying and briefly got a normal screen that flickered and died.. plugged back into PC and it has reset back to 02/08/09 again and random orange LED flashing again.. unplugged and screen flickered and died again...plugged in and getting double flash of orange LED and battery showing full charge...now back to random single and double orange flash
now shows double flash when on PC but when I unplug I get vertical lines flashing across the screen and battery symbol is at zero despite it being on USB for 4 hours
If it is relevant, this is the first time it has been dived (replacement unit following recall of my first unit)
Completely dead other than occasional flashes when not on USB to PC..can't get it to stay on for more than 10 seconds...now completely dead...no reaction to left or right button..cannot switch on at all - unit is dead
Next day - unit still locked and dead..but with solid BLUE LED..can't switch on when on PC or off
ewatsch
hi gordon,
maybe you should open the battery compartment and look if there's also a water leakage.
ewatsch
ewatsch
lamentin
hello,
there is room to put a 3 O-ring on the USB plug.
I did it with a little silicone grease.
gordon mackie
yes - battery compartment flood
back to the factory
back to the factory
Gizmo
Not good news, i was hoping this problem had been rectified. I had been waiting for them to come back in stock at Deep Ideas, but now i think i will leave it a month or two to see if this is an isolated problem or connected to the recall.
I know it would be replaced quick enough (from reading others experience) but i don't want the hassle to be computer less for a couple of weeks.
D20
I had a similar problem and the unit was replaced into a new one very quickly. According to Matthias about 40 units from December were affected and replaced for free.
Mine is fine now
Mine is fine now
Hi Gordon,
Don't worry - you'll have a new unit asap.
gordon mackie
I know Matthias - the customer service with you guys is fantastic - and I still think the Mk2 is the best computer I have ever used!
Larscousteau
I had the same problem and i must say that i am impressed bye the service from heinrichsweikamp. now i have a new unit.
But should i be worry?
should i put a extra o-ring in the USB plug or ??
Attached is a picture showing an alternative O-Ring setup for the plug (Easier removal). Three O-Rings are not required but if you'd like to add a third one: It's 10x1.8 FKM 80 A
Christofer
heinrichsweikamp Wrote:
> Hi Gordon,
> Cheers,
This happened to me as well today. Have just e-mailed you. Hope we can solve it just as quickly.
Best regards,
Christofer
> Hi Gordon,
> Cheers,
Best regards,
Christofer
_______________________
OSTC Mk II #358
OSTC Mk II #358
Christofer
"Hope we can solve it just as quickly."
And that we could. Kudos to your costumer support!
OSTC Mk II #358
OSTC Mk II #358
gordon mackie
My new model, 3 O ring Mk2 arrived today... it will get a good run on the U12 on Sunday
Thanks again Matthias
gordon mackie
Perfect
30 mins at 48 metres - no problems
and with GF 85/15 it was a good match with my VR3
VR3 did first stop at 27, Mk2 was 21
VR3 was 11 mins at 6 and Mk2 was 13
So they work well together
