Did a short dive under ice. Mostly just trying to be upside down under the ice. Max depth was 5.1m and the depth graph is missing from the log.
Only have two dives + the factory testing "dive" on the unit.
The first dive a week ago (19.2.2022) shows correct graph, but on the latest dive there is no depth graph although it shows that max depth was 5.1m.
So what should I do?
Dive details not logged
Re: Dive details not logged
More information? What type of computer? What firmware? What altitude did you do the dive at? How long was the dive?
Oh sorry the attachments did not come trough.
For some reason I can't attach the photos so I had to put them to my onedrive: https://1drv.ms/u/s!AgyZs4MSaiIHjqY0j8 ... ?e=2aqBZ4
I have the latest firmware. Just bought the OSTC4 at the end of last year and first time dived with it a week ago because I was not qualified to go under the ice till last weekend.
When I try to download the last dive with mobile subsurface, I get nothing even the bluetooth connection is established successfully.
What altitude was the dive at?
At Tampere Finland so it's about 84m from sea level.
The reason why I am asking is because at high altitude the computer starts the dive only once you go past 4m depth or so (or at least that how it was with the 2N)
As the divetime is 15 Minutses there should be some data.
Have you tryed to download the profile with a external program like OSTCProfile to see the real data?
maybe the line is to "flat" to see on the device.
Mobile subsurfaca force download only downloads two dives.
OSTC Profile gets following error:
HWOS GetAllDivingProfile
Save path: C:\Users\valtt\Documents\OSTCTools\Profiles\
Port: COM6
OSTC3 Version is 7609
OSTC3 Identity 1024
Gelesen: 65536 bytes.
NumberOfProfiles: 3
retrieving profile no: 1
Profilesize: 12346
OSTC3 ERROR: ReadOneDiveFromDC(1, 12346, ...) results
LOG: Create
LOG: Connect
LOG: Config
LOG: send byte 0xBB
LOG: recieved byte 0xBB
LOG: recieved byte 0x4D
LOG: send byte 0x69
LOG: recieved byte 0x69
LOG: now start recieving 65 bytes.
LOG: 65 bytes read, last byte is 4D
LOG: finally
LOG: lastbyte (64) is 0x4Dis READYDONE.
LOG: ReadVersionIdentityFromDC
LOG: send byte 0x6A
LOG: recieved byte 0x6A
LOG: now start recieving 2 bytes.
LOG: 2 bytes read, last byte is 4D
LOG: finally
LOG: lastbyte (1) is 0x4Dis READYDONE.
LOG: ReadHardwareDescriptorFromDC
LOG: send byte 0x61
LOG: recieved byte 0x61
LOG: now start recieving 65537 bytes.
LOG: 65537 bytes read, last byte is 4D
LOG: finally
LOG: lastbyte (65536) is 0x4Dis READYDONE.
LOG: ReadAllProfileHeaderFromDC
LOG: send byte 0x66
LOG: recieved byte 0x66
LOG: send byte 0x00
LOG: now start recieving 12347 bytes.
ERROR: 3290 bytes read, last byte is 00 Errorno: 9997 Errormsg: Timeout during operation
LOG: finally
LOG: lastbyte (3289) is 0x00is NOT READYDONE.
LOG: ReadOneDiveFromDC
retrieving profile no: 2
Profilesize: 13424
OSTC3 ERROR: ReadOneDiveFromDC(2, 13424, ...) results
LOG: Create
LOG: Connect
LOG: Config
LOG: send byte 0xBB
LOG: send byte 0x69
LOG: finally
LOG: send byte 0x6A
LOG: finally
LOG: send byte 0x61
LOG: finally
LOG: send byte 0x66
LOG: send byte 0x00
LOG: finally
LOG: send byte 0x66
LOG: send byte 0x01
LOG: now start recieving 13425 bytes.
LOG: finally
retrieving profile no: 3
Profilesize: 7019
OSTC3 ERROR: ReadOneDiveFromDC(3, 7019, ...) results
LOG: Create
LOG: Connect
LOG: Config
LOG: send byte 0xBB
LOG: send byte 0x69
LOG: finally
LOG: send byte 0x6A
LOG: finally
LOG: send byte 0x61
LOG: finally
LOG: send byte 0x66
LOG: send byte 0x00
LOG: finally
LOG: send byte 0x66
LOG: send byte 0x01
LOG: finally
LOG: send byte 0x66
LOG: send byte 0x02
LOG: now start recieving 7020 bytes.
LOG: finally
Found 0 dives on disk.
Found 0 dives in profile.
Saved 0 dives to disk.
Port: COM6
OSTC3 Identity 1024
NumberOfProfiles: 3
Profilesize: 12346
LOG: Create
LOG: Connect
LOG: Config
LOG: send byte 0xBB
LOG: send byte 0x69
LOG: finally
LOG: send byte 0x6A
LOG: finally
LOG: send byte 0x61
LOG: finally
LOG: send byte 0x66
LOG: send byte 0x00
LOG: finally
Profilesize: 13424
LOG: Create
LOG: Connect
LOG: Config
LOG: send byte 0xBB
LOG: send byte 0x69
LOG: finally
LOG: send byte 0x6A
LOG: finally
LOG: send byte 0x61
LOG: finally
LOG: send byte 0x66
LOG: send byte 0x00
LOG: finally
LOG: send byte 0x66
LOG: send byte 0x01
LOG: finally
Profilesize: 7019
LOG: Create
LOG: Connect
LOG: Config
LOG: send byte 0xBB
LOG: send byte 0x69
LOG: finally
LOG: send byte 0x6A
LOG: finally
LOG: send byte 0x61
LOG: finally
LOG: send byte 0x66
LOG: send byte 0x00
LOG: finally
LOG: send byte 0x66
LOG: send byte 0x01
LOG: finally
LOG: send byte 0x66
LOG: send byte 0x02
LOG: finally
