The new hwOS tech (for OSTC3, OSTC plus, OSTC+, cR, OSTC 2 and OSTC sport (mod. 19)) firmware 3.21 is now available for download:
[3.21]
MD5: 62eae67e83fd5527cc205b8acbc37bf6
FIX: Wrong release date in 3.20 showed "Update!" message prematurely
CHANGE: Compatibility for new hardware versions
CHANGE: Reduce default bottom time for simulator from 10' to 2'
FIX: BLE was on after first reboot (until sleepmode kicks in)
[3.20]
MD5: c0e1430ec55b4f22ef21fc5a71afd0e3
Bugfix: Some USB hardware version showed USB mode insetad of BLE Mode
[3.19]
MD5: 9e79db5fa4f2f72086ce83abd3ee279f
BUGFIX: Increase resolution of tissue pressure calculations to track very low pressure differences between ambient and tissue pressures
CHANGE: OSTC with mechanical (magnetic) buttons need both buttons beeing pressed to wake up
CHANGE: Support for new OSTC+ hardware with O2 sensor inputs
CHANGE: Adjust max. brightness settings
CHANGE: reset planning parameters to default values - only when entering the menu,
thus keeping the settings between multiple calculator runs
FIX: the output of the calculation results was divided into several steps, which
could be interrupted in cooperative multitasking. So glitches could occur in the
screen output if e.g. the TTS switched to NDL but the deco data flag vector was
not updated yet. Now the compilation of all calculation results can no longer be
interrupted.
[3.18]
BUGFIX: Properly update desaturation time and tissue data after battery change (OSTC with user-replaceable batteries only)
NEW: Option to suppress non-critical warnings in dive mode
CHANGE: Do not present gas6 option in alternative layout (Switch to normal layout in order to configure the gas 6 during the dive)
CHANGE: Do not show RX portions of tank setup menu when there is no RX hardware
CHANGE: Low-level code improvements for performance
[3.17]
[3.16]
BUGFIX: Sensor detection in OSTC plus could fail for some hardware versions
BUGFIX: calculate time/date of the end of the dive in logbook screen correctly for
dives with a lot of surface time/many descents
NEW: Different brightness settings for dive and surface mode
NEW: minor changes in the different language versions
BUGFIX: Reduce sleep mode current
[3.15]
NEW: Support for new pressure sensor type in OSTC 2 and plus
NEW: Several changes in the different language versions
CHANGE: Tweak gas use routine to work with unplanned changes (Switching to inactive gases)
NEW: Big dive mode menu in big layout view
BUGFIX: fix pulsing brightness in ECO on some hardware versions
CHANGE: support for internal hardware changes
CHANGE: adjust gas density parameters to match upcoming new ISO standard
Die neue hwOS tech Firmware 3.21 (für OSTC3, OSTC plus, OSTC+, cR, OSTC 2 und OSTC sport (mod. 19)) ist jetzt zum kostenlosen Download verfügbar:
[3.21]
FIX: Falsches Veröffentlichungsdatum in 3.20 zeigte verfrüht "Update!
CHANGE: Kompatibilität für neue Hardware-Versionen
ÄNDERUNG: Standard-Bottomtime für den Simulator von 10' auf 2' reduziert
FIX: BLE war nach dem ersten Neustart eingeschaltet (bis der Sleepmode einsetzte)
[3.20]
Bugfix: Einige USB-Hardware-Versionen zeigten den USB-Modus anstelle des BLE-Modus
[3.19]
BUGFIX: Die Auflösung der Gewebedruckberechnungen wurde erhöht, um sehr geringe Druckunterschiede zwischen Umgebungs- und Gewebedruck zu erfassen.
ÄNDERUNG: Bei OSTC mit mechanischen (magnetischen) Tasten müssen zum Aufwachen beide Tasten gedrückt werden
ÄNDERUNG: Unterstützung für neue OSTC+ Hardware mit O2-Sensoreingängen
ÄNDERUNG: Anpassung der maximalen Helligkeitseinstellungen
ÄNDERUNG: Zurücksetzen der Planungsparameter auf die Standardwerte, aber nur beim Aufrufen des Menüs.
Dadurch bleiben die Einstellungen zwischen mehreren Rechenläufen erhalten
FIX: die Ausgabe der Berechnungsergebnisse war in mehrere Schritte unterteilt, was bei
die bei kooperativem Multitasking unterbrochen werden konnten. Dadurch konnte es zu Störungen in der
Bildschirmausgabe auftreten, wenn z.B. der TTS auf NDL umschaltet, aber der Deko-Daten-Flag-Vektor
noch nicht aktualisiert wurde. Jetzt kann die Kompilierung aller Berechnungsergebnisse nicht mehr
unterbrochen werden.
[3.18]
BUGFIX: Korrekte Aktualisierung der Entsättigungszeit und der Gewebedaten nach einem Batteriewechsel (nur OSTC mit vom Benutzer austauschbaren Batterien)
NEU: Option zur Unterdrückung unkritischer Warnungen im Tauchmodus
ÄNDERUNG: Die Option gas6 wird im alternativen Layout nicht angezeigt (Wechseln Sie zum normalen Layout, um das Gas 6 während des Tauchgangs zu konfigurieren)
ÄNDERUNG: Teile des RX-Menüs im Tank-Setup werden nicht angezeigt, wenn keine RX-Hardware vorhanden ist
ÄNDERUNG: Low-Level-Code-Verbesserungen für mehr Leistung
[3.17]
NEU: Unterstützung für die aktuelle Hardware-Version von OSTC 2, plus und Sport
- ein Reset Bluetooth aus dem Reset-Menü kann erforderlich sein, um BLE/Bluetooth 4.0 zu aktivieren
[3.16]
BUGFIX: Sensorerkennung in OSTC plus konnte bei einigen Hardware-Versionen fehlschlagen
BUGFIX: Die Berechnung von Zeit/Datum des Tauchgangsendes im Logbuchbildschirm bei Tauchgängen mit viel Oberflächenzeit/vielen Abstiegen
NEW: Unterschiedliche Helligkeitseinstellungen für Tauch- und Oberflächenmodus
NEW: Kleine Änderungen in den verschiedenen Sprachversionen
BUGFIX: Stromverbrauch im Schlafmodus reduziert
[3.15]
NEU: Unterstützung für neuen Drucksensor in OSTC 2 und plus
NEU: Sprachupdates
ÄNDERUNG: Verhalten beim Wechsel auf inaktive Gase
BUGFIX: Hintergrundbeleuchtung konnte unter bestimmten Bedingungen pulsieren
NEU: In der Großansicht wird das Tauchmodus-Menü in großer Schrift (Eine Zeile) dargestellt
Bitte Fragen zum Updateprozess/Probleme beim Update in einem neuen Thread posten.
How to install: viewtopic.php?f=6&t=14509
hwOS TECH: New Firmware 3.21
Christophe
Re: hwOS TECH: New Firmware 3.21
Bonjour,
Installé ce jour sur mon OSTC2.
Merci pour le suivi et les mises à jour régulières :)
Da fehlt noch ein "t"
Siehe Bild im Anhang.
[attachment=0]Screenshot 2023-06-27 103209.png[/attachment]
Und noch eine Information:
Mein OSTC 2 (#18807) hatte auch unter v3.20 noch immer unregelmässig "USB Modus" anstatt "Bluetooth Modus" angezeigt. Gemäss Changelog hätte das in 3.20 jedoch schon gefixt sein müssen?
Bezüglich des "t": hier ist mal nicht die Firmware schuld, der Text in diesem Bereich wird vom verbundenen PC / der App geschickt, der OSTC stellt ihn nur dar. Und dieser Text ist leider 1 Zeichen zu lang für das Ausgabefeld...
Bonjour.
Installé correctement sur deux OSTC 3.
Depuis il m'est impossible de les connecter en USB via OSTC Companion v3.2 beta 1.
Last month a friend of mine got his computer back from HW with the firmware upgraded to 3.22, but this firmware is not available for download. Any reason ?
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
The 3.22 will be published in the next days.
Continue here: viewtopic.php?t=22518
