v1.86 beta simulator deco profile comparisons
smcmullan
Post by smcmullan »
I've run the simulator for a CCR deco plan of 99m for bottom times of 15 mins up to 39 mins and compared with the outputs of APD Projection and V-Planner
Please see results in file attached.
I have setpoint 1.3, GFs 15/85 or +2 conservatism for VPM and diluent 10/70
I think its obvious that there is a serious problem with the Simulator deco planner for OSTC
I do my diving in this range so am very interested to see it recognised as a problem to be fixed.
Is this a problem only with the Simulator? Will I also get these TTS readings on actual dives?
Thanks,
Stephen Mcmullan
OSTC MK #850
Stephen McMullan
Dublin, Ireland
OSTC MK2 #850
www.technicaldiving.ie
Re: v1.86 beta simulator deco profile comparisons
Hi Stephen,
Maybe indeed an issue with the run-time simulator (Which uses a different routine then in normal divemode). If you dive this dive with the real-time simulator in divemode you'll get:
RT:TTS [both in minutes]
15:113
17:131
19:144
21:164
23:182
25:198
27:214
29:236
31:258
33:266
35:291
37:307
39:324
Total decoplan at RT=39min will be:
m :min
72: 2
69: 1
66: 1
63: 2
60: 2
57: 2
54: 2
51: 3
48: 4
45: 3
42: 5
39: 5
36: 5
33: 8
30: 8
27: 9
24: 13
21: 14
18: 18
15: 22
12: 28
9: 35
6: 49
3: 85
We'll look after this issue, of course. Thanks for reporting so detailed.
smcmullan
Post by smcmullan »
Great support for a Saturday evening Matthias!
Thanks very much for the response. It gives me a lot of confidence in the device and now that I know the dive mode routine is different than the run time simulator I'll be patient awaiting a fix :-)
The figures produced by the dive mode real time simulator look just fine.
I'd be willing to pay for that piece of software as a planner (especially if it was an Android app) ;-)
Thanks again,
Stephen
Stephen McMullan
Dublin, Ireland
OSTC MK2 #850
JeanDo
Post by JeanDo »
With a 900mbar sea pressure, I get the following plot:
[img]https://bitbucket-assetroot.s3.amazonaw ... %4099m.png[/img]
Cheers.
smcmullan
Post by smcmullan »
Hi JeanDo,
I'm not sure what software application you are using to generate that graph?
Is it a visualisation of the OSTC Mk2 Simulator/deco planner?
I'm using the device directly to generate the TTS times for 99m for 15-39min bottom times
One thing I forgot to mention is that my last stop is configured to 6m. We don't do last stop 3m in the north Atlantic :-)
Don't get too focussed on the 39min profile. According to the MK2 the TTS for 99m for bottom times 25->37mins is 219minutes and if you stay till 39mins it jumps to 370mins
Likewise if you do a nice 23mins bottom time you get 132mins TTS but if you stay 2 minutes longer then you get a shock :-)
Of course this is all on the Simulator/deco planner and not in the water as Matthias explained.
Regards, Stephen
OSTC MK2 #850
Stephen McMullan
Dublin, Ireland
OSTC MK2 #850
JeanDo
Post by JeanDo »
Ok, I corrected the 1.86beta decoplanning. (See there https://bitbucket.org/heinrichsweikamp/ ... aab4ca0547)
It is way faster. And correct.
No you have:
[pre]
| Bottom | TTS |
| 15' | 125' |
| 17' | 144' |
| 19' | 163' |
| 21' | 182' |
| 23' | 200' |
| 25' | 220' |
| 27' | 239' |
| 29' | 261' |
| 31' | 282' |
| 33' | 306' |
| 35' | 329' |
| 37' | 350' |
| 39' | 368' |
[/pre]
Munch thanks for the bug report !
smcmullan
Post by smcmullan »
Superb. Thank you JeanDo and Matthias for the effort. I look forward to the next beta release :)
Stephen McMullan
Dublin, Ireland
OSTC MK2 #850
Regthing
Post by Regthing »
JeanDo.
Did you have the same setup that Mathhias used above as he has different run times from the dive mode simulation he ran?
Scott
JeanDo
Post by JeanDo »
Hello Regthing,
Same settings, except I most probably set ambiant pressure to 900mbar, and corrected the bug reported by Stephen inbetween.
Heiko
Post by Heiko »
maybe it falls in the same corner as Stephens bug:
O2 at position one in the gaslist is not part of the Diveplan and the Decoplan during simulation.
ZHL OC GF
GF 10/85
last 6m
CF55 3
gaslist
Gas usage:
G1:02 6m active
G2:50/15 21m active
G3:100/0 6m
G4:21/35 0m
G5:18/45 0m active/first
Diveplan:
19min/60m
6 32
9 5
12 3
15 3
21 3
24 2
27 1
30 1
39 1
Diveplan:
same dive, without O2
gaslist
Gas usage:
G1:02 6m
G2:50/15 21m active
G3:100/0 6m
G4:21/35 0m
6 32
9 5
12 3
15 3
21 3
24 2
27 1
30 1
39 1
no differents, by experience the stop at 6m is like without O2.
Simulator:
after switching to O2 on 6m the decotime switched from 39min to 23min, moreless the time I expect for this dive with O2.
Everthing else looks very nice ! Thanks, great job.
Heiko
Hubertus
1.83 beta Logbuch
Post by Hubertus »
Ich habe jetzt in einer Woche 10 Tg´s gemacht . Leider habe ich jetzt gemerkt das eder MK2 nur noch die 4 letzten Tg´s hat.
Ist das Problem bekannt ??? Gibt es das bei der 1.86 noch ?
Solodiver
Post by Solodiver »
Hubertus, this something off topic in here, you should have started a new thread or use the 1.83 one. If you only see the last dives this my have something to do with your dive profile and sampling rate (CF21 ff. if I remember correctly). Please check them and post the settings in here if you are unsure.
BTW: I also realized that I have only 10 dives in my log book listed which has been much more in the past. Could others please check if there is also a change in their logs to make sure there is no issue in this topic?
Thx,
