Deco
O2diver
Deco
Post by O2diver »
During the decompression stop when time is less than 1 minute, the computer shows the next stop. I think that less than a minute should include a stopwatch and accurately show the remaining time to decompress.
tiefunten
Re: Deco
Post by tiefunten »
The computer only shows the next stop, when the time of the stop before is finished. In my opinion, there is no need for a stopwatch here. But if you think so, you can add a stopwatch using the custom-views and a cf. Furthermore, you can switch the time to show the seconds all the time.
dmainou
Re: Deco
Post by dmainou »
The count down to zero will only be accurate when buoyancy is perfectly maintained so I think there is no point in adding one.
You may wish to activate the "seconds" CF and that will give you a good indicator.
D
OSTC MK2 1394
JeanDo
Re: Deco
Post by JeanDo »
Furthermore, it won't work even if you stays put at stop+1m, because it displays 1min even when you need just a few seconds. The rounding up is part of the algorithme and can't easily be removed...
Re: Deco
With all the uncertainties in deco algorithms, a second-exact deco display is nonsense.
