Deco
Re: Deco
The computer only shows the next stop, when the time of the stop before is finished. In my opinion, there is no need for a stopwatch here. But if you think so, you can add a stopwatch using the custom-views and a cf. Furthermore, you can switch the time to show the seconds all the time.
Re: Deco
Furthermore, it won't work even if you stays put at stop+1m, because it displays 1min even when you need just a few seconds. The rounding up is part of the algorithme and can't easily be removed...
Re: Deco
With all the uncertainties in deco algorithms, a second-exact deco display is nonsense.
