I've updated my unit to the latest FW recently. Yesterday I've notice that the clock was about 14 hours behind the true time.
It's quite some time ago that I last checked the time on my unit but was pretty much OK by that time. I was surpriced that the setting was that much wrong. I have no idea if this is in some way correlated to the FW update. Has any one of you noticed anything similar?
Time setting changed during FW update?
Peter
OSTC 2N #2338
Peter
OSTC 2N #2338
Re: Time setting changed during FW update?
Hi Peter,
I might well be:
* What version did you upgrade from/to ?
* What is the CF48 value ?
I might well be:
Hi JeanDo,
I've upgraded from 2.00 to 2.01. Default is used for CF48. Any ideas on that?
Peter
OSTC 2N #2338
Peter
OSTC 2N #2338
As far as I have observed, the time is reset to 0, each time I upgrade to a new firmware ...
Have you upgraded your OSTC around 14h just after your nap ???
OSTC 2N #2755
The clock is completely made out of software. Sorry, but the time must be set again after the bootloader/reboot process.
Thanks for the clarification Matthias. Now that I know it's not a problem. I just have to keep it in mind.
Peter
OSTC 2N #2338
Peter
OSTC 2N #2338
BTW clock, how can I switch between the european and american data standard:
American: mmddyy
European: ddmmyy
thx Lukas
American: mmddyy
European: ddmmyy
thx Lukas
