I believe if we get this to work properly this will set a new standard for dive computers.
We propose to integrate the Bail Counter with a bookmark functionality to store the Bailcounter values. These waypoints can then, if selected during the dive, be used as a starting value for the counter. If I take the same example as I did in the post for the bail counter it would work like this.
You start with 2000L of bailout when entering the cave. After 300 L there is a Jump you want to swim, but not until on the way home. You create a waypoint and the value 300L is stored.
Continue in and after 1000L there is a T. You want to swim to both the left and the right side of the T and thus create a new waypoint with the value of 1000L. Start with the right side of the T and continue until you reach max B/O range of 2000L. The counter goes red and you turn toward home.
Back at the T is where the good things begin. You go into the waypoint menu and select waypoint 2 with the value of 1000L. This will reset the bail counter to the value stored in the waypoint and make it start counting upwards from 1000L.The amount needed to get you out!
Now you swim to the left side of the T and find a second T after another 500L. Go into the waypoint menu and create waypoint 3 with a value of 1500L. Choose if you first want to go right or left and then keep diving until the counter shows 2000L and go red again.
Turn back to the T and select waypoint 3 with value of 1500L. The counter restarts from 1500L and you can now swim on the other side of the second T while the counter ticks towards B/O range.
Done with all that and on the way home you find the jump you saved for later. Select waypoint 1, which will restart the counter from 300L, and keep on enjoying the dive. All this while always easily keeping track of how far in terms of bailout you are from the surface!
This would of course require a new submenu for the stored waypoints and I believe the select gas menu would be a good model for this. The difference is it should only be accessible when Cave Bail is shown in the custom view and it needs to have as first item a store or create waypoint option.
Hopefully you will understand how useful this would be both for us divers and as a market advantage for HW. If you have any questions or concerns i am more than willing to try to help answer them.
/ [DF]
