Three bugs(?) in Firmware 2.20 / Drei Käfer(?) in Firmware 220
Post by Rob »
Hi there,
i found some bugs in Firmware Version 220.
First:
The easy one: in EEProm Bank 0 the "total number of cf used in firmware" is wrong!
I recieve 58.
But this was never the number of CF in Firmware, this was always "the last CF in firmware".
CF counting starts with 0 not with 1 (this seems to be a major problem in all the descriptions, not only with CF (perhaps also in code?).
Second:
In my last dive i got an never ending stop at 21m.
(maybe this is related to http://www.heinrichsweikamp.com/read.php?2,7782)
I did a sililar dive before were the stop times were ok.
What was different:
I prepared my OSTC with the following gases:
Selected Gas at begin of dive (2): 21/30
Gas 1: 12/55
Gas 2: 21/30
Gas 3: 31/35
Gas 4: 49/0 at 21m
Gas 5: 100/0 at 6m
Gas 6: 30/0
The Gasses 2, 4, 5 where shown as used (color in the gaslist)
Active Gases were 2,3,4,5
But i decieded to use gas 2,3 and 5 during the dive
At 37m i changed the gas to Gas no 3 (TMX 31/35).
Third:
At the end of the dive i provoked some ppo2 high warnings
one warning i got is at 6,35m thats ok bit in the following i have several times when i was deeper then this and i recieved NO warning in the logfile.
Here is the profile data of the dive and my CF Settings.
regards
Servus miteinander,
ich habe ein paar bugs in Firmware Version 2.20 gefunden.
Erstens:
Der leichte ;-) in EEPROM Bank 0 das byte für "total number of cf used in firmware" ist falsch.
Ich erhalte hier 58 als Wert, eigentlich sollten es 60 sein.
Aber der Eintrag war ja noch nie dir Anzahl der CF in der Firmware, es war vielmehr die letzte CF Nummer der Firmware.
Das Zählen der CF startet bei 0 und nicht bei 1 (Aber das Zählproblem des StartBytes zieht sich durch die gesamte Dokumentation, nicht nur bei den CF (vieleicht auch im Code?)
Zweitens:
Bei meinem letzten Tauchgang hatte ich einen nicht endenden Stop bei 21m.
(ich denke das passt auch zu http://www.heinrichsweikamp.com/read.php?2,7782)
Bei einem ähnlichen Tauchgang war heir alles ok.
Der Unterschied war:
Ich stellte folgende Gase am OSTC ein:
Gewähltes Gas bei TG beginn (2): 21/30
Gas 1: 12/55
Gas 2: 21/30
Gas 3: 31/35
Gas 4: 49/0 bei 21m
Gas 5: 100/0 bei 6m
Gas 6: 30/0
Gas Nummer 2, 4, 5 wurden als genutzte Gase angezeigt (Farbe in der Gasliste).
Aktive Gase waren 2,3,4,5
Ich entschied mich aber die Gase 2,3 and 5 für den Tauchgang zu verwenden.
Auf 37m wechselte ich zu Gas Nr. 3 (TMX 31/35).
Drittens:
Am Ende des Tauchgangs provutierte ich ein paar ppO2 high warnings.
eine Warnung erhielt ich auf 6,35m, das ist ja ok, aber im Folgenden war ich einige male tiefer als die 6,35m und im Logzeitgte sich keine ppO2 Warnung.
Grüße
Hier noch die Profildaten und die Custom Functions.
Filename: 0794_11-02-2012_060m_063min
DiveFileversion: 100
LogBookProfileVersion: 33
DiveNumber: 794
Date of dive: 11.02.2012
Time at begin of dive: 12:13:00
Time at end of dive: 13:17:00
Maximum depth (mbar): 6047
Maximum depth (bar): 6,047
Divetime: 63min 39sec
Gas 1: 12/55
Gas 2: 21/30
Gas 3: 31/35
Gas 4: 49/0
Gas 5: 100/0
Gas 6: 30/0
Minimum water temperature: 3,1
Surface air pressure (mBar): 932
Desaturation time after dive (min): 677
Maximum CNS (%): 42
Average depth: 2123 mbar
Total divetime: 4059 sec.
GFLo: 30
GFHi: 80
Decotype: ZH-L16-GF OC
Firmware version: 220
Battery voltage in mV after dive: 4,144
Salinity: 1
Sampling rate (sec): 10
Sampling divisor temperature: 6 information size 32
Sampling divisor deco/NDL: 6 information size 32
Sampling divisor tank pressure: 0 information size 16
Sampling divisor ppO2 sensors: 0 information size 48
Sampling divisor deco debug: 8 information size 0
Profile data
ProfileOffset: 258
Number of ProfileEntries: 405
values after the | are byte the bytes starting at byte 3 (Profile Byte) shown as (hex)Binary
pos( 1) T: 0:00 D: 231 | (00)00000000
pos( 2) T: 0:10 D: 313 | (00)00000000
pos( 3) T: 0:20 D: 311 | (00)00000000
pos( 4) T: 0:30 D: 349 | (00)00000000
pos( 5) T: 0:40 D: 434 | (00)00000000
pos( 6) T: 0:50 D: 570 TEMP=32 Deco Stop at 0m Stop 240min | (04)00000100 (20)00100000 (00)00000000 (00)00000000 (F0)11110000
pos( 7) T: 1:00 D: 714 | (00)00000000
pos( 8) T: 1:10 D: 803 | (00)00000000
pos( 9) T: 1:20 D: 865 | (00)00000000
pos( 10) T: 1:30 D: 1017 | (00)00000000
pos( 11) T: 1:40 D: 1019 | (00)00000000
pos( 12) T: 1:50 D: 1090 TEMP=35 Deco Stop at 0m Stop 90min | (04)00000100 (23)00100011 (00)00000000 (00)00000000 (5A)01011010
pos( 13) T: 2:00 D: 1233 | (00)00000000
pos( 14) T: 2:10 D: 1291 | (00)00000000
pos( 15) T: 2:20 D: 1323 | (00)00000000
pos( 16) T: 2:30 D: 1356 | (00)00000000
pos( 17) T: 2:40 D: 1378 | (00)00000000
pos( 18) T: 2:50 D: 1425 TEMP=36 Deco Stop at 0m Stop 43min | (04)00000100 (24)00100100 (00)00000000 (00)00000000 (2B)00101011
pos( 19) T: 3:00 D: 1537 | (00)00000000
pos( 20) T: 3:10 D: 1626 | (00)00000000
pos( 21) T: 3:20 D: 1733 | (00)00000000
pos( 22) T: 3:30 D: 1748 | (00)00000000
pos( 23) T: 3:40 D: 1818 | (00)00000000
pos( 24) T: 3:50 D: 1807 TEMP=36 Deco Stop at 0m Stop 23min | (04)00000100 (24)00100100 (00)00000000 (00)00000000 (17)00010111
pos( 25) T: 4:00 D: 1790 | (00)00000000
pos( 26) T: 4:10 D: 1766 | (00)00000000
pos( 27) T: 4:20 D: 1810 | (00)00000000
pos( 28) T: 4:30 D: 1884 | (00)00000000
pos( 29) T: 4:40 D: 1954 | (00)00000000
pos( 30) T: 4:50 D: 2057 TEMP=36 Deco Stop at 0m Stop 16min | (04)00000100 (24)00100100 (00)00000000 (00)00000000 (10)00010000
pos( 31) T: 5:00 D: 2160 | (00)00000000
pos( 32) T: 5:10 D: 2239 | (00)00000000
pos( 33) T: 5:20 D: 2358 | (00)00000000
pos( 34) T: 5:30 D: 2461 | (00)00000000
pos( 35) T: 5:40 D: 2481 | (00)00000000
pos( 36) T: 5:50 D: 2589 TEMP=37 Deco Stop at 0m Stop 8min | (04)00000100 (25)00100101 (00)00000000 (00)00000000 (08)00001000
pos( 37) T: 6:00 D: 2626 | (00)00000000
pos( 38) T: 6:10 D: 2729 | (00)00000000
pos( 39) T: 6:20 D: 2855 | (00)00000000
pos( 40) T: 6:30 D: 2965 | (00)00000000
pos( 41) T: 6:40 D: 3062 | (00)00000000
pos( 42) T: 6:50 D: 3179 TEMP=38 Deco Stop at 0m Stop 4min | (04)00000100 (26)00100110 (00)00000000 (00)00000000 (04)00000100
pos( 43) T: 7:00 D: 3244 | (00)00000000
pos( 44) T: 7:10 D: 3325 | (00)00000000
pos( 45) T: 7:20 D: 3380 | (00)00000000
pos( 46) T: 7:30 D: 3435 | (00)00000000
pos( 47) T: 7:40 D: 3461 | (00)00000000
pos( 48) T: 7:50 D: 3505 TEMP=39 Deco Stop at 0m Stop 3min | (04)00000100 (27)00100111 (00)00000000 (00)00000000 (03)00000011
pos( 49) T: 8:00 D: 3540 | (00)00000000
pos( 50) T: 8:10 D: 3590 | (00)00000000
pos( 51) T: 8:20 D: 3680 | (00)00000000
pos( 52) T: 8:30 D: 3738 | (00)00000000
pos( 53) T: 8:40 D: 3811 | (00)00000000
pos( 54) T: 8:50 D: 3879 TEMP=39 Deco Stop at 0m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (00)00000000 (01)00000001
pos( 55) T: 9:00 D: 3966 | (00)00000000
pos( 56) T: 9:10 D: 4075 | (00)00000000
pos( 57) T: 9:20 D: 4168 | (00)00000000
pos( 58) T: 9:30 D: 4288 | (00)00000000
pos( 59) T: 9:40 D: 4378 | (00)00000000
pos( 60) T: 9:50 D: 4460 TEMP=38 Deco Stop at 6m Stop 1min | (04)00000100 (26)00100110 (00)00000000 (06)00000110 (01)00000001
pos( 61) T:10:00 D: 4559 | (00)00000000
pos( 62) T:10:10 D: 4639 | (00)00000000
pos( 63) T:10:20 D: 4671 | (00)00000000
pos( 64) T:10:30 D: 4798 | (00)00000000
pos( 65) T:10:40 D: 4891 | (00)00000000
pos( 66) T:10:50 D: 4991 TEMP=39 Deco Stop at 9m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (09)00001001 (01)00000001
pos( 67) T:11:00 D: 5092 | (00)00000000
pos( 68) T:11:10 D: 5171 | (00)00000000
pos( 69) T:11:20 D: 5196 | (00)00000000
pos( 70) T:11:30 D: 5270 | (00)00000000
pos( 71) T:11:40 D: 5374 | (00)00000000
pos( 72) T:11:50 D: 5511 TEMP=39 Deco Stop at 15m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (0F)00001111 (01)00000001
pos( 73) T:12:00 D: 5615 | (00)00000000
pos( 74) T:12:10 D: 5672 | (00)00000000
pos( 75) T:12:20 D: 5731 | (00)00000000
pos( 76) T:12:30 D: 5770 | (00)00000000
pos( 77) T:12:40 D: 5766 | (00)00000000
pos( 78) T:12:50 D: 5749 TEMP=39 Deco Stop at 15m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (0F)00001111 (01)00000001
pos( 79) T:13:00 D: 5833 | (00)00000000
pos( 80) T:13:10 D: 5830 | (00)00000000
pos( 81) T:13:20 D: 5889 | (00)00000000
pos( 82) T:13:30 D: 5912 | (00)00000000
pos( 83) T:13:40 D: 5884 | (00)00000000
pos( 84) T:13:50 D: 5832 TEMP=40 Deco Stop at 18m Stop 1min | (04)00000100 (28)00101000 (00)00000000 (12)00010010 (01)00000001
pos( 85) T:14:00 D: 5818 | (00)00000000
pos( 86) T:14:10 D: 5792 | (00)00000000
pos( 87) T:14:20 D: 5761 | (00)00000000
pos( 88) T:14:30 D: 5699 | (00)00000000
pos( 89) T:14:40 D: 5638 | (00)00000000
pos( 90) T:14:50 D: 5599 TEMP=40 Deco Stop at 21m Stop 1min | (04)00000100 (28)00101000 (00)00000000 (15)00010101 (01)00000001
pos( 91) T:15:00 D: 5545 | (00)00000000
pos( 92) T:15:10 D: 5513 | (00)00000000
pos( 93) T:15:20 D: 5533 | (00)00000000
pos( 94) T:15:30 D: 5499 | (00)00000000
pos( 95) T:15:40 D: 5427 | (00)00000000
pos( 96) T:15:50 D: 5387 TEMP=41 Deco Stop at 21m Stop 1min | (04)00000100 (29)00101001 (00)00000000 (15)00010101 (01)00000001
pos( 97) T:16:00 D: 5358 | (00)00000000
pos( 98) T:16:10 D: 5384 | (00)00000000
pos( 99) T:16:20 D: 5415 | (00)00000000
pos( 100) T:16:30 D: 5437 | (00)00000000
pos( 101) T:16:40 D: 5422 | (00)00000000
pos( 102) T:16:50 D: 5397 TEMP=41 Deco Stop at 21m Stop 1min | (04)00000100 (29)00101001 (00)00000000 (15)00010101 (01)00000001
pos( 103) T:17:00 D: 5386 | (00)00000000
pos( 104) T:17:10 D: 5356 | (00)00000000
pos( 105) T:17:20 D: 5322 | (00)00000000
pos( 106) T:17:30 D: 5246 | (00)00000000
pos( 107) T:17:40 D: 5161 | (00)00000000
pos( 108) T:17:50 D: 5097 TEMP=42 Deco Stop at 21m Stop 1min | (04)00000100 (2A)00101010 (00)00000000 (15)00010101 (01)00000001
pos( 109) T:18:00 D: 4990 | (00)00000000
pos( 110) T:18:10 D: 4924 | (00)00000000
pos( 111) T:18:20 D: 4862 | (00)00000000
pos( 112) T:18:30 D: 4750 | (00)00000000
pos( 113) T:18:40 D: 4737 | (00)00000000
pos( 114) T:18:50 D: 4703 TEMP=42 Deco Stop at 21m Stop 1min | (04)00000100 (2A)00101010 (00)00000000 (15)00010101 (01)00000001
pos( 115) T:19:00 D: 4547 | (00)00000000
pos( 116) T:19:10 D: 4432 | (00)00000000
pos( 117) T:19:20 D: 4325 | (00)00000000
pos( 118) T:19:30 D: 4209 | (00)00000000
pos( 119) T:19:40 D: 4137 | (00)00000000
pos( 120) T:19:50 D: 4038 TEMP=43 Deco Stop at 21m Stop 1min | (04)00000100 (2B)00101011 (00)00000000 (15)00010101 (01)00000001
pos( 121) T:20:00 D: 3934 | (00)00000000
pos( 122) T:20:10 D: 3821 | (00)00000000
pos( 123) T:20:20 D: 3811 | (00)00000000
pos( 124) T:20:30 D: 3875 | (00)00000000
pos( 125) T:20:40 D: 3814 | (00)00000000
pos( 126) T:20:50 D: 3773 TEMP=43 Deco Stop at 21m Stop 1min | (04)00000100 (2B)00101011 (00)00000000 (15)00010101 (01)00000001
pos( 127) T:21:00 D: 3777 | (00)00000000
pos( 128) T:21:10 D: 3761 | (00)00000000
pos( 129) T:21:20 D: 3733 | (00)00000000
pos( 130) T:21:30 D: 3738 | (00)00000000
pos( 131) T:21:40 D: 3721 gas Change to 1 no alarm | (82)10000010 (20)00100000 (01)00000001
pos( 132) T:21:50 D: 3730 gas Change to 3 no alarm TEMP=42 Deco Stop at 21m Stop 1min | (86)10000110 (20)00100000 (03)00000011 (2A)00101010 (00)00000000 (15)00010101 (01)00000001
pos( 133) T:22:00 D: 3680 | (00)00000000
pos( 134) T:22:10 D: 3595 | (00)00000000
pos( 135) T:22:20 D: 3463 | (00)00000000
pos( 136) T:22:30 D: 3340 | (00)00000000
pos( 137) T:22:40 D: 3253 | (00)00000000
pos( 138) T:22:50 D: 3173 TEMP=43 Deco Stop at 21m Stop 1min | (04)00000100 (2B)00101011 (00)00000000 (15)00010101 (01)00000001
pos( 139) T:23:00 D: 3075 | (00)00000000
pos( 140) T:23:10 D: 2973 | (00)00000000
pos( 141) T:23:20 D: 2910 | (00)00000000
pos( 142) T:23:30 D: 2814 | (00)00000000
pos( 143) T:23:40 D: 2724 | (00)00000000
pos( 144) T:23:50 D: 2633 TEMP=43 Deco Stop at 21m Stop 1min | (04)00000100 (2B)00101011 (00)00000000 (15)00010101 (01)00000001
pos( 145) T:24:00 D: 2523 | (00)00000000
pos( 146) T:24:10 D: 2400 | (00)00000000
pos( 147) T:24:20 D: 2311 | (00)00000000
pos( 148) T:24:30 D: 2212 | (00)00000000
pos( 149) T:24:40 D: 2279 | (00)00000000
pos( 150) T:24:50 D: 2373 TEMP=39 Deco Stop at 21m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (15)00010101 (01)00000001
pos( 151) T:25:00 D: 2456 | (00)00000000
pos( 152) T:25:10 D: 2446 | (00)00000000
pos( 153) T:25:20 D: 2359 | (00)00000000
pos( 154) T:25:30 D: 2263 | (00)00000000
pos( 155) T:25:40 D: 2198 | (00)00000000
pos( 156) T:25:50 D: 2146 TEMP=40 Deco Stop at 21m Stop 1min | (04)00000100 (28)00101000 (00)00000000 (15)00010101 (01)00000001
pos( 157) T:26:00 D: 2137 | (00)00000000
pos( 158) T:26:10 D: 2111 | (00)00000000
pos( 159) T:26:20 D: 2117 | (00)00000000
pos( 160) T:26:30 D: 2083 | (00)00000000
pos( 161) T:26:40 D: 2099 | (00)00000000
pos( 162) T:26:50 D: 2093 TEMP=39 Deco Stop at 21m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (15)00010101 (01)00000001
pos( 163) T:27:00 D: 2116 | (00)00000000
pos( 164) T:27:10 D: 2155 | (00)00000000
pos( 165) T:27:20 D: 2189 | (00)00000000
pos( 166) T:27:30 D: 2200 | (00)00000000
pos( 167) T:27:40 D: 2179 | (00)00000000
pos( 168) T:27:50 D: 2189 TEMP=39 Deco Stop at 21m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (15)00010101 (01)00000001
pos( 169) T:28:00 D: 2207 | (00)00000000
pos( 170) T:28:10 D: 2201 | (00)00000000
pos( 171) T:28:20 D: 2152 | (00)00000000
pos( 172) T:28:30 D: 2145 | (00)00000000
pos( 173) T:28:40 D: 2067 | (00)00000000
pos( 174) T:28:50 D: 2037 TEMP=39 Deco Stop at 21m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (15)00010101 (01)00000001
pos( 175) T:29:00 D: 2054 | (00)00000000
pos( 176) T:29:10 D: 2051 | (00)00000000
pos( 177) T:29:20 D: 2067 | (00)00000000
pos( 178) T:29:30 D: 2111 | (00)00000000
pos( 179) T:29:40 D: 2096 | (00)00000000
pos( 180) T:29:50 D: 2057 TEMP=39 Deco Stop at 21m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (15)00010101 (01)00000001
pos( 181) T:30:00 D: 2018 | (00)00000000
pos( 182) T:30:10 D: 2045 | (00)00000000
pos( 183) T:30:20 D: 2047 | (00)00000000
pos( 184) T:30:30 D: 2073 | (00)00000000
pos( 185) T:30:40 D: 2032 | (00)00000000
pos( 186) T:30:50 D: 2058 TEMP=38 Deco Stop at 21m Stop 1min | (04)00000100 (26)00100110 (00)00000000 (15)00010101 (01)00000001
pos( 187) T:31:00 D: 2098 | (00)00000000
pos( 188) T:31:10 D: 2088 | (00)00000000
pos( 189) T:31:20 D: 2071 | (00)00000000
pos( 190) T:31:30 D: 2047 | (00)00000000
pos( 191) T:31:40 D: 1996 | (00)00000000
pos( 192) T:31:50 D: 1971 gas Change to 1 no alarm TEMP=39 Deco Stop at 21m Stop 1min | (86)10000110 (20)00100000 (01)00000001 (27)00100111 (00)00000000 (15)00010101 (01)00000001
pos( 193) T:32:00 D: 1949 gas Change to 1 no alarm | (82)10000010 (20)00100000 (01)00000001
pos( 194) T:32:10 D: 1899 gas Change to 2 no alarm | (82)10000010 (20)00100000 (02)00000010
pos( 195) T:32:20 D: 1789 | (00)00000000
pos( 196) T:32:30 D: 1652 | (00)00000000
pos( 197) T:32:40 D: 1506 | (00)00000000
pos( 198) T:32:50 D: 1524 TEMP=39 Deco Stop at 9m Stop 5min | (04)00000100 (27)00100111 (00)00000000 (09)00001001 (05)00000101
pos( 199) T:33:00 D: 1515 | (00)00000000
pos( 200) T:33:10 D: 1521 | (00)00000000
pos( 201) T:33:20 D: 1530 | (00)00000000
pos( 202) T:33:30 D: 1542 | (00)00000000
pos( 203) T:33:40 D: 1518 | (00)00000000
pos( 204) T:33:50 D: 1545 TEMP=38 Deco Stop at 9m Stop 4min | (04)00000100 (26)00100110 (00)00000000 (09)00001001 (04)00000100
pos( 205) T:34:00 D: 1553 | (00)00000000
pos( 206) T:34:10 D: 1603 | (00)00000000
pos( 207) T:34:20 D: 1632 | (00)00000000
pos( 208) T:34:30 D: 1672 | (00)00000000
pos( 209) T:34:40 D: 1629 | (00)00000000
pos( 210) T:34:50 D: 1670 TEMP=37 Deco Stop at 9m Stop 4min | (04)00000100 (25)00100101 (00)00000000 (09)00001001 (04)00000100
pos( 211) T:35:00 D: 1722 | (00)00000000
pos( 212) T:35:10 D: 1734 | (00)00000000
pos( 213) T:35:20 D: 1794 | (00)00000000
pos( 214) T:35:30 D: 1836 | (00)00000000
pos( 215) T:35:40 D: 1787 | (00)00000000
pos( 216) T:35:50 D: 1786 TEMP=38 Deco Stop at 9m Stop 3min | (04)00000100 (26)00100110 (00)00000000 (09)00001001 (03)00000011
pos( 217) T:36:00 D: 1747 | (00)00000000
pos( 218) T:36:10 D: 1742 | (00)00000000
pos( 219) T:36:20 D: 1713 | (00)00000000
pos( 220) T:36:30 D: 1703 | (00)00000000
pos( 221) T:36:40 D: 1694 | (00)00000000
pos( 222) T:36:50 D: 1664 TEMP=38 Deco Stop at 9m Stop 3min | (04)00000100 (26)00100110 (00)00000000 (09)00001001 (03)00000011
pos( 223) T:37:00 D: 1689 | (00)00000000
pos( 224) T:37:10 D: 1702 | (00)00000000
pos( 225) T:37:20 D: 1692 | (00)00000000
pos( 226) T:37:30 D: 1666 | (00)00000000
pos( 227) T:37:40 D: 1619 | (00)00000000
pos( 228) T:37:50 D: 1576 TEMP=39 Deco Stop at 9m Stop 2min | (04)00000100 (27)00100111 (00)00000000 (09)00001001 (02)00000010
pos( 229) T:38:00 D: 1479 | (00)00000000
pos( 230) T:38:10 D: 1445 | (00)00000000
pos( 231) T:38:20 D: 1418 | (00)00000000
pos( 232) T:38:30 D: 1398 | (00)00000000
pos( 233) T:38:40 D: 1387 | (00)00000000
pos( 234) T:38:50 D: 1333 TEMP=39 Deco Stop at 9m Stop 2min | (04)00000100 (27)00100111 (00)00000000 (09)00001001 (02)00000010
pos( 235) T:39:00 D: 1326 | (00)00000000
pos( 236) T:39:10 D: 1317 | (00)00000000
pos( 237) T:39:20 D: 1297 | (00)00000000
pos( 238) T:39:30 D: 1201 | (00)00000000
pos( 239) T:39:40 D: 1167 | (00)00000000
pos( 240) T:39:50 D: 1153 TEMP=41 Deco Stop at 9m Stop 1min | (04)00000100 (29)00101001 (00)00000000 (09)00001001 (01)00000001
pos( 241) T:40:00 D: 1115 | (00)00000000
pos( 242) T:40:10 D: 1072 | (00)00000000
pos( 243) T:40:20 D: 1066 | (00)00000000
pos( 244) T:40:30 D: 1094 | (00)00000000
pos( 245) T:40:40 D: 1049 | (00)00000000
pos( 246) T:40:50 D: 993 TEMP=41 Deco Stop at 6m Stop 13min | (04)00000100 (29)00101001 (00)00000000 (06)00000110 (0D)00001101
pos( 247) T:41:00 D: 997 | (00)00000000
pos( 248) T:41:10 D: 1021 | (00)00000000
pos( 249) T:41:20 D: 1040 | (00)00000000
pos( 250) T:41:30 D: 1098 | (00)00000000
pos( 251) T:41:40 D: 1096 | (00)00000000
pos( 252) T:41:50 D: 1074 TEMP=40 Deco Stop at 6m Stop 13min | (04)00000100 (28)00101000 (00)00000000 (06)00000110 (0D)00001101
pos( 253) T:42:00 D: 1063 | (00)00000000
pos( 254) T:42:10 D: 1063 | (00)00000000
pos( 255) T:42:20 D: 1005 | (00)00000000
pos( 256) T:42:30 D: 968 | (00)00000000
pos( 257) T:42:40 D: 1028 | (00)00000000
pos( 258) T:42:50 D: 1056 TEMP=39 Deco Stop at 6m Stop 13min | (04)00000100 (27)00100111 (00)00000000 (06)00000110 (0D)00001101
pos( 259) T:43:00 D: 999 | (00)00000000
pos( 260) T:43:10 D: 953 | (00)00000000
pos( 261) T:43:20 D: 956 | (00)00000000
pos( 262) T:43:30 D: 877 | (00)00000000
pos( 263) T:43:40 D: 800 | (00)00000000
pos( 264) T:43:50 D: 797 TEMP=39 Deco Stop at 6m Stop 13min | (04)00000100 (27)00100111 (00)00000000 (06)00000110 (0D)00001101
pos( 265) T:44:00 D: 768 | (00)00000000
pos( 266) T:44:10 D: 727 | (00)00000000
pos( 267) T:44:20 D: 693 | (00)00000000
pos( 268) T:44:30 D: 659 | (00)00000000
pos( 269) T:44:40 D: 653 | (00)00000000
pos( 270) T:44:50 D: 624 TEMP=38 Deco Stop at 6m Stop 13min | (04)00000100 (26)00100110 (00)00000000 (06)00000110 (0D)00001101
pos( 271) T:45:00 D: 615 | (00)00000000
pos( 272) T:45:10 D: 598 | (00)00000000
pos( 273) T:45:20 D: 587 | (00)00000000
pos( 274) T:45:30 D: 603 gas Change to 5 no alarm | (82)10000010 (20)00100000 (05)00000101
pos( 275) T:45:40 D: 586 | (00)00000000
pos( 276) T:45:50 D: 628 TEMP=38 Deco Stop at 6m Stop 12min | (04)00000100 (26)00100110 (00)00000000 (06)00000110 (0C)00001100
pos( 277) T:46:00 D: 629 | (00)00000000
pos( 278) T:46:10 D: 643 | (00)00000000
pos( 279) T:46:20 D: 640 | (00)00000000
pos( 280) T:46:30 D: 636 | (00)00000000
pos( 281) T:46:40 D: 636 | (00)00000000
pos( 282) T:46:50 D: 637 TEMP=37 Deco Stop at 6m Stop 11min | (04)00000100 (25)00100101 (00)00000000 (06)00000110 (0B)00001011
pos( 283) T:47:00 D: 670 | (00)00000000
pos( 284) T:47:10 D: 700 ppO high warning | (81)10000001 (05)00000101
pos( 285) T:47:20 D: 700 ppO high warning | (81)10000001 (05)00000101
pos( 286) T:47:30 D: 658 ppO high warning | (81)10000001 (05)00000101
pos( 287) T:47:40 D: 675 | (00)00000000
pos( 288) T:47:50 D: 679 ppO high warning TEMP=36 Deco Stop at 6m Stop 10min | (85)10000101 (05)00000101 (24)00100100 (00)00000000 (06)00000110 (0A)00001010
pos( 289) T:48:00 D: 653 ppO high warning | (81)10000001 (05)00000101
pos( 290) T:48:10 D: 618 | (00)00000000
pos( 291) T:48:20 D: 597 | (00)00000000
pos( 292) T:48:30 D: 611 | (00)00000000
pos( 293) T:48:40 D: 609 | (00)00000000
pos( 294) T:48:50 D: 603 TEMP=36 Deco Stop at 6m Stop 9min | (04)00000100 (24)00100100 (00)00000000 (06)00000110 (09)00001001
pos( 295) T:49:00 D: 622 | (00)00000000
pos( 296) T:49:10 D: 664 | (00)00000000
pos( 297) T:49:20 D: 668 | (00)00000000
pos( 298) T:49:30 D: 702 ppO high warning | (81)10000001 (05)00000101
pos( 299) T:49:40 D: 709 ppO high warning | (81)10000001 (05)00000101
pos( 300) T:49:50 D: 719 ppO high warning TEMP=36 Deco Stop at 6m Stop 8min | (85)10000101 (05)00000101 (24)00100100 (00)00000000 (06)00000110 (08)00001000
pos( 301) T:50:00 D: 719 ppO high warning | (81)10000001 (05)00000101
pos( 302) T:50:10 D: 727 ppO high warning | (81)10000001 (05)00000101
pos( 303) T:50:20 D: 741 ppO high warning | (81)10000001 (05)00000101
pos( 304) T:50:30 D: 747 ppO high warning | (81)10000001 (05)00000101
pos( 305) T:50:40 D: 703 ppO high warning | (81)10000001 (05)00000101
pos( 306) T:50:50 D: 635 ppO high warning TEMP=35 Deco Stop at 6m Stop 7min | (85)10000101 (05)00000101 (23)00100011 (00)00000000 (06)00000110 (07)00000111
pos( 307) T:51:00 D: 606 | (00)00000000
pos( 308) T:51:10 D: 612 | (00)00000000
pos( 309) T:51:20 D: 655 | (00)00000000
pos( 310) T:51:30 D: 679 ppO high warning | (81)10000001 (05)00000101
pos( 311) T:51:40 D: 654 ppO high warning | (81)10000001 (05)00000101
pos( 312) T:51:50 D: 650 TEMP=35 Deco Stop at 6m Stop 6min | (04)00000100 (23)00100011 (00)00000000 (06)00000110 (06)00000110
pos( 313) T:52:00 D: 623 | (00)00000000
pos( 314) T:52:10 D: 612 | (00)00000000
pos( 315) T:52:20 D: 587 | (00)00000000
pos( 316) T:52:30 D: 582 | (00)00000000
pos( 317) T:52:40 D: 620 | (00)00000000
pos( 318) T:52:50 D: 615 TEMP=36 Deco Stop at 6m Stop 5min | (04)00000100 (24)00100100 (00)00000000 (06)00000110 (05)00000101
pos( 319) T:53:00 D: 631 | (00)00000000
pos( 320) T:53:10 D: 613 | (00)00000000
pos( 321) T:53:20 D: 597 | (00)00000000
pos( 322) T:53:30 D: 615 | (00)00000000
pos( 323) T:53:40 D: 614 | (00)00000000
pos( 324) T:53:50 D: 649 TEMP=36 Deco Stop at 6m Stop 4min | (04)00000100 (24)00100100 (00)00000000 (06)00000110 (04)00000100
pos( 325) T:54:00 D: 654 | (00)00000000
pos( 326) T:54:10 D: 668 | (00)00000000
pos( 327) T:54:20 D: 704 ppO high warning | (81)10000001 (05)00000101
pos( 328) T:54:30 D: 646 ppO high warning | (81)10000001 (05)00000101
pos( 329) T:54:40 D: 641 | (00)00000000
pos( 330) T:54:50 D: 633 TEMP=35 Deco Stop at 6m Stop 3min | (04)00000100 (23)00100011 (00)00000000 (06)00000110 (03)00000011
pos( 331) T:55:00 D: 650 | (00)00000000
pos( 332) T:55:10 D: 664 | (00)00000000
pos( 333) T:55:20 D: 642 | (00)00000000
pos( 334) T:55:30 D: 626 | (00)00000000
pos( 335) T:55:40 D: 635 | (00)00000000
pos( 336) T:55:50 D: 659 TEMP=35 Deco Stop at 6m Stop 2min | (04)00000100 (23)00100011 (00)00000000 (06)00000110 (02)00000010
pos( 337) T:56:00 D: 674 ppO high warning | (81)10000001 (05)00000101
pos( 338) T:56:10 D: 681 ppO high warning | (81)10000001 (05)00000101
pos( 339) T:56:20 D: 682 ppO high warning | (81)10000001 (05)00000101
pos( 340) T:56:30 D: 718 ppO high warning | (81)10000001 (05)00000101
pos( 341) T:56:40 D: 740 ppO high warning | (81)10000001 (05)00000101
pos( 342) T:56:50 D: 676 ppO high warning TEMP=35 Deco Stop at 6m Stop 1min | (85)10000101 (05)00000101 (23)00100011 (00)00000000 (06)00000110 (01)00000001
pos( 343) T:57:00 D: 687 ppO high warning | (81)10000001 (05)00000101
pos( 344) T:57:10 D: 700 ppO high warning | (81)10000001 (05)00000101
pos( 345) T:57:20 D: 674 ppO high warning | (81)10000001 (05)00000101
pos( 346) T:57:30 D: 623 | (00)00000000
pos( 347) T:57:40 D: 642 | (00)00000000
pos( 348) T:57:50 D: 688 ppO high warning TEMP=35 Deco Stop at 0m Stop 240min | (85)10000101 (05)00000101 (23)00100011 (00)00000000 (00)00000000 (F0)11110000
pos( 349) T:58:00 D: 690 ppO high warning | (81)10000001 (05)00000101
pos( 350) T:58:10 D: 655 ppO high warning | (81)10000001 (05)00000101
pos( 351) T:58:20 D: 638 | (00)00000000
pos( 352) T:58:30 D: 633 | (00)00000000
pos( 353) T:58:40 D: 665 | (00)00000000
pos( 354) T:58:50 D: 692 ppO high warning TEMP=35 Deco Stop at 0m Stop 240min | (85)10000101 (05)00000101 (23)00100011 (00)00000000 (00)00000000 (F0)11110000
pos( 355) T:59:00 D: 706 ppO high warning | (81)10000001 (05)00000101
pos( 356) T:59:10 D: 706 ppO high warning | (81)10000001 (05)00000101
pos( 357) T:59:20 D: 701 ppO high warning | (81)10000001 (05)00000101
pos( 358) T:59:30 D: 660 ppO high warning | (81)10000001 (05)00000101
pos( 359) T:59:40 D: 681 ppO high warning | (81)10000001 (05)00000101
pos( 360) T:59:50 D: 718 ppO high warning TEMP=34 Deco Stop at 0m Stop 240min | (85)10000101 (05)00000101 (22)00100010 (00)00000000 (00)00000000 (F0)11110000
pos( 361) T:60:00 D: 709 ppO high warning | (81)10000001 (05)00000101
pos( 362) T:60:10 D: 690 ppO high warning | (81)10000001 (05)00000101
pos( 363) T:60:20 D: 656 ppO high warning | (81)10000001 (05)00000101
pos( 364) T:60:30 D: 649 | (00)00000000
pos( 365) T:60:40 D: 595 | (00)00000000
pos( 366) T:60:50 D: 573 TEMP=34 Deco Stop at 0m Stop 240min | (04)00000100 (22)00100010 (00)00000000 (00)00000000 (F0)11110000
pos( 367) T:61:00 D: 540 | (00)00000000
pos( 368) T:61:10 D: 440 | (00)00000000
pos( 369) T:61:20 D: 421 | (00)00000000
pos( 370) T:61:30 D: 420 | (00)00000000
pos( 371) T:61:40 D: 383 | (00)00000000
pos( 372) T:61:50 D: 341 TEMP=34 Deco Stop at 0m Stop 240min | (04)00000100 (22)00100010 (00)00000000 (00)00000000 (F0)11110000
pos( 373) T:62:00 D: 344 | (00)00000000
pos( 374) T:62:10 D: 316 | (00)00000000
pos( 375) T:62:20 D: 266 | (00)00000000
pos( 376) T:62:30 D: 210 | (00)00000000
pos( 377) T:62:40 D: 192 | (00)00000000
pos( 378) T:62:50 D: 201 TEMP=33 Deco Stop at 0m Stop 240min | (04)00000100 (21)00100001 (00)00000000 (00)00000000 (F0)11110000
pos( 379) T:63:00 D: 185 | (00)00000000
pos( 380) T:63:10 D: 174 | (00)00000000
pos( 381) T:63:20 D: 124 | (00)00000000
pos( 382) T:63:30 D: 99 | (00)00000000
pos( 383) T:63:40 D: 34 | (00)00000000
pos( 384) T:63:50 D: 42 TEMP=34 Deco Stop at 0m Stop 240min | (04)00000100 (22)00100010 (00)00000000 (00)00000000 (F0)11110000
pos( 385) T:64:00 D: 45 | (00)00000000
pos( 386) T:64:10 D: 30 | (00)00000000
pos( 387) T:64:20 D: 9 | (00)00000000
pos( 388) T:64:30 D: 26 | (00)00000000
pos( 389) T:64:40 D: 12 | (00)00000000
pos( 390) T:64:50 D: 23 TEMP=33 Deco Stop at 0m Stop 240min | (04)00000100 (21)00100001 (00)00000000 (00)00000000 (F0)11110000
pos( 391) T:65:00 D: 3 | (00)00000000
pos( 392) T:65:10 D: 16 | (00)00000000
pos( 393) T:65:20 D: 18 | (00)00000000
pos( 394) T:65:30 D: 8 | (00)00000000
pos( 395) T:65:40 D: 6 | (00)00000000
pos( 396) T:65:50 D: 2 TEMP=33 Deco Stop at 0m Stop 240min | (04)00000100 (21)00100001 (00)00000000 (00)00000000 (F0)11110000
pos( 397) T:66:00 D: 4 | (00)00000000
pos( 398) T:66:10 D: 4 | (00)00000000
pos( 399) T:66:20 D: 17 | (00)00000000
pos( 400) T:66:30 D: 15 | (00)00000000
pos( 401) T:66:40 D: 23 | (00)00000000
pos( 402) T:66:50 D: 52 TEMP=33 Deco Stop at 0m Stop 240min | (04)00000100 (21)00100001 (00)00000000 (00)00000000 (F0)11110000
pos( 403) T:67:00 D: 27 | (00)00000000
pos( 404) T:67:10 D: 4 | (00)00000000
pos( 405) T:67:20 D: 4 | (00)00000000
End of Dive
number of CF: 58 (3A)00111010
CF00 Act: 100 Def: 100
CF01 Act: 30 Def: 30
CF02 Act: 240 Def: 240
CF03 Act: 120 Def: 120
CF04 Act: 5 Def: 5
CF05 Act: 7 Def: 7
CF06 Act: 1160 Def: 1160
CF07 Act: 1080 Def: 1080
CF08 Act: 20 Def: 20
CF09 Act: 20 Def: 20
CF10 Act: 45 Def: 45
CF11 Act: 110 Def: 110
CF12 Act: 90 Def: 90
CF13 Act: 60 Def: 60
CF14 Act: 100 Def: 100
CF15 Act: 10 Def: 10
CF16 Act: 10 Def: 10
CF17 Act: 19 Def: 19
CF18 Act: 160 Def: 160
CF19 Act: 150 Def: 150
CF20 Act: 10 Def: 10
CF21 Act: 6 Def: 6
CF22 Act: 6 Def: 6
CF23 Act: 0 Def: 0
CF24 Act: 0 Def: 0
CF25 Act: 0 Def: 0
CF26 Act: 0 Def: 0
CF27 Act: 20 Def: 20
CF28 Act: 794 Def: 0
CF29 Act: 6 Def: 3
CF30 Act: 10 Def: 10
CF31 Act: 0 Def: 0
CF32 Act: 30 Def: 30
CF33 Act: 80 Def: 90
CF34 Act: 199 Def: 199
CF35 Act: 255 Def: 255
CF36 Act: 62 Def: 62
CF37 Act: 224 Def: 224
CF38 Act: 1 Def: 0
CF39 Act: 0 Def: 0
CF40 Act: 1 Def: 1
CF41 Act: 1 Def: 1
CF42 Act: 1 Def: 1
CF43 Act: 13000 Def: 13000
CF44 Act: 101 Def: 101
CF45 Act: 101 Def: 101
CF46 Act: 161 Def: 161
CF47 Act: 10 Def: 15
CF48 Act: 0 Def: 0
CF49 Act: 0 Def: 0
CF50 Act: 0 Def: 0
CF51 Act: 1 Def: 1
CF52 Act: 1 Def: 0
CF53 Act: 1 Def: 0
CF54 Act: 0 Def: 0
CF55 Act: 0 Def: 0
CF56 Act: 20 Def: 200
CF57 Act: 20 Def: 200
CF58 Act: 0 Def: 0
CF59 Act: 0 Def: 0
CF60 Act: 1 Def: 0
End of CF --------------------------------------
Re: Three bugs(?) in Firmware 2.20 / Drei Käfer(?) in Firmware 220
I'm confused... We do not have any statement about your second issue from HW so far. Or did i miss something? We still don't know if it is a bug or a feature...
Post by Rob »
> feature...
If a one minute stop is after 5 minutes still there then it is a bug. (Or the OSTC builds a small wormhole around itself)
Maybe the information with the used gasses and the detailed logbook helps HW to find and fix the problem.
regards
rob
Rob, you did not switch to gas G4 at 21m, right? And gas G4 was still active? So it could be a feature to tell you that there is a better gas available, then the one you've chosen...
I would like to see a function which asks me "Switch to Gas G4" (in your example gas G4 = 49/0) if i reach the 21m stopp. Then i can decide to say "yes" or "no". If i say no i should still be able to switch to the gas (or another) manualy...
So hopefully HW will turn this "bug" into a "feature"... ;)
Post by Rob »
No i dont, i decided to use the 30/35
but this is the situation when you have planned to use a 21m gas (the EAN49) but you lost it.
I had the feeling that a normal deco was shown after i switched back to the 21/3x (active gas and first gas) that i used and one reason for the problem is that i switched to a gas that the OSTC is not using for its decoplan.
The OSTC should calculate with the gas that is used(selected) at the moment.
It can show me that there is a better gas (this is done in the lower left oft the ostc) but the decompression stop of one minute must diappear when the deco with the selected gas is done.
regards
I agree 100%.
JeanDo
Post by JeanDo »
Actually, what you ask for is confusing (for the computer): You decided not to use Gas4. But you never tell the OSTC...
What I try to explain is the computer cannot read your mind and guess that, and it can neither assume you won't go deeper again and need Gas#4 at some later time. So it is unable to automatically deselect Gas#4 for you.
Btw, we are concerned by this issue. The next firmware will most probably display the gas change delay with a timer, around the changing depth (eg. +/- 1.5 m), and then go silent afterward.
Post by Rob »
Hi JeanDo,
How can i tell this to the computer? Under Water, not at the surface.
Or should i switch to Gas4 and then immediately switch back to another gas?
Sorry, this is somthing the computer shuld not do.
But it shuld remove a one minute dekostop after 5 minutes.
I dont ask for automaitcally select or deselect of gasses.
I just want to have a correct dekoplan shown in the display.
An that includes that a deco stop is cleard when the dekotime in the stopdepth is over.
As you can see in the profiledata i had for more than 6 minutes no dekoinformation shown on my computer only this silly stop 1 min at 21m.
This stop was gone when i start messing around with selecting other gasses,
gasses i dint breath, you can see i switched to the 30/35 before i reached the 21m stop depth.
> Regards,
regards
i haven't dived my MK2 with FW 2.2 but i did some simulations and mine showed the exact same behaviour.
This behaviour was known before with CF 55 set to > 0 min.
Now it happens with CF 55 set to 0 min aswell.
If this behaviour is programmed by intention there should be a CF to switch it off.
I you loose an active gas and you are not aware of this behaviour you might waste some valuable time or even run out of usable gas.
My half cent, Reiner
Solodiver
Post by Solodiver »
I also had some issues when not switching to O2 at 6m lately. As this has the first and only OC dive in more than a year and I'm not going to do this again I'm not able to reproduce this. Just a confirmation of the behavior described above.
I also had only the 6m stop (and nothing more!) in my deco plan but after ignoring the 6m stop the unit showed 1min @3m suddenly followed by a cleared deco shortly after. The unit might still be set to last stop @6m, but I'm not sure about this. So it seems the unit is able to ignore the gas switch in some way?
I would like to see something like this:
[img]http://divenow.ch/files/gasswitch.jpg[/img]
It appears whenever you reach a stop matching a defined gas, for example EAN50@21m
It should disappear automatically after 30 seconds and OSTC should calculate the decoplan without the recommended gas, unless i press yes or i do switch the gas manually later.
Regthing
Post by Regthing »
There has already been a lot of discussion regarding prompts to switch gas and it was stated that HW policy is to ensure at least 3 button presses before a gas switch and that the OSTC isn't designed to make or prompt decisions. Flogging a dead horse I'm I'm afraid.
Scott
that's ok to me!
But it is not ok to me when the unit freezes the deco-calculation when no gas-switching happens.
That's ok for me too, but then i need no informations nor notifications about better gas or possible gas switch at all...
Solodiver
Post by Solodiver »
No, please don't! BTW: 30s is just much to short for a notification and a following (possible) gas switch.
I agree that the current behavior is not perfect at all, but please lets find other solutions!
Thx,
Post by Rob »
Hi there,
sorry that my bug report switches to a feature request.
That was not in my mind when i wrote the report.
I gave all the information and ideas i have, to make it easier to find or solve the bugs.
When the "non switch" to the dekogas is the problem, how about "enter the gas selection dialog, select a gas (even when the gas is the actual used gas) and thats the gas the ostc calculates instead of the suggested one.
(This is just a idea, not a feature request)
And PLEASE do me a favour, dont turn the good ostc firmware into a "deko dodo" with funny pics and dialogs everywhere. Ok, for me the Gas switch dialog could be a bit bigger (in size) i need glasses for reading and sometimes the gas switch or stopwatch reset needs to much time to identify. (Yes i have reading glasses in my masks, but...)
> dialogs everywhere.
That's not the idea of my idea ;)
But the question is: Will a future firmware support the diver during his/her dive or not, and how? I don't need any dialogs about gas switching at all, because i do the gas switches when i want. But then we don't need any yellow blinking gases or delays too! IMHO
@solodiver: 30 seconds are enough to recognize a notification. Especially during ascent a diver will check the computer quite often, just because not to miss a stopp depth or to check ascent rate... Anyway i don't stick to 30 seconds, this could be 45 or 60 seconds aswell, as long as i can say No within seconds...
And hey - it's just an idea to keep a discussion alive :)
Solodiver
Post by Solodiver »
Why not adding the ability to disable (enable?) gases in the water? In this case nothing in the current usability has to be changed (except the stucked deco ceiling described above).
tiefunten
Post by tiefunten »
It is already possible to disable and enable gases during the dive: Gaslist > More > Active? > Then you can select the gas of which you want to change the status and disable/enable with the right button!
Es sit doch bereits möglich, Gase während dem TG zu aktivieren oder deaktivieren: Gaslist, dann More, dann Active? anklicken, im darauffolgenden Fenster kann man dann mit dem linken Knopf das jeweilige Gas anwählen und mit dem rechten Knopf an oder ausschalten (das Gas wechselt dann die Farbe, weiß für aktiv und dunkelblau für inaktiv).
Post by Rob »
Hi there,
the gas i used the 30/35 was active from the beginning of the dive.
but i failed to set a changedepth for this gas, so it stud at the color "blue" and not white as the other gasses.
regards
rob
Nur als Anmerkung, das Gas das ich genutzt habe (30/35) war von Beginn des Tauchgangs an aktiv. Aber ich habe vergessen eine Gaswechseltiefe für das gas einzugeben, daher blieb es in der Farbe dunkelblau markiert und war nicht weiß wie die anderen Gase.
Grüße
Setting the changedepth to 0m is the same like deactivating the gas.
tiefunten
Post by tiefunten »
I think Rob knows that. Nevertheless the gas should work as well when you select it even if it is deactivated. The single problem is that the OSTC stuck at 21m when it should have recalculated deco using the gas you are currently breathing when you don't switch to another gas within a few minutes.
Solodiver
Post by Solodiver »
No, IMHO the deco should just be recalculated when a gas deactivated (or activated). But the deco ceiling should not get stuck when a change is not done but should allow to continue the dive with the current gas (which means longer deco times).
Cool, then there is no need for any (additional) change except removing this bug with the locked deco ceiling.
My EUR 0.02,
tiefunten
Post by tiefunten »
In fact I meant exactly what you wrote here. When you don't switch to an active deco gas, deco should be recalculated using the gas which is currently active after a few minutes. That is exactly how the Ostc behaved before... don't know were this bug comes from but I would be interested in a comment from Matthias or Christian on this topic!
Me too...
At this point i have another question: How is OSTC calculating the deco plan? Let's do a dive down to 60m for 20 Min with a TMX 18/45. As soon as i get into deco, my OSTC will calculate a deco plan. Is this plan only based on the actual breathing gas and recalculated whenever a gas change is done, or is the OSTC "looking into the future" and calculates the deco plan already with expected gas changes @21m and @6m, if i have activated G2:50/00@21m and G3:100/00@6m, for example?
