servan Wrote:
> No. Does the yellow led blinking when I try to
> reset ? Or always ?
If the battery voltage is critical (caused by whatever) the battery is hard-disconnected from the OSTC (To avoid battery under-discharging) and will reconnect after the interface is attached and the reset button is pressed for some minutes. Yellow LED is blinking every 15seconds two times if battery is very low but not critical. OSTC can not be powered on unless connected to the charger.
Thank you for the answer.
How many minutes should I wait ? I've pressed 3 minutes and nothing...
