Hello !
My remarks are :
Simulation mode :
When exiting and reentering simulation mode, depth and divetime are reseted to 3min /15m. It is very annoying when the depth is far above 15m (30 clics for 105m)
Surface mode /Gas setup :
from 21 to 99 % O2 for example= 78 clics
Dive mode / Gaslist
No exit. To exit : select the current gas (which is not reported) or more/more/close
Dive mode / Gaslist
to modify G6, il you want 99/0 and clic once too, you have 95 clics more clics to return to 99/0
Dive mode
The name of the current gas is not reported (G1->G6)
CFII / depthAlarm
13000 -> 600 = 70 clics even with step 100
In brief, there is too much clics mainly in dive mode and moreover in fall-back procedure.
Bernard
Whishlist man-machine interface
Re: Whishlist man-machine interface
> for 105m)
Its not hard to tap fast with your fingertip 30 times (4 seconds?)
Change + to - and go in reverse
> Dive mode / Gaslist
As above
> CFII / depthAlarm
How often do you do this? 70 clicks takes me about 10 seconds...
> for 105m)
> Dive mode / Gaslist
As above
> CFII / depthAlarm
Why do you need to change the depth alarm? Or need one for that matter!?
That makes no sense! You have to monitor you dive computer during the dive anyway, or are you telling me that during a dive YOU are not aware at what depths you are diving!?
The Depth Alarm is set to 130m because the OSTC has a max operating depth of 130m.
Therefore we have many software like OSTCTools, OSTC Planner and others to change the CF's... With almost no clicks >:D<
