Hi Everyone.
In Receipt of my OSTC2 Which is running HWOS 1.88. I can not get it connect to my windows 7 Laptop of my new Windows 10 Laptop via Bluetooth. All paired ok and if I switch off and then back on the Bluetooth on the laptop it says connected (on the Bluetooth settings) but for about 3 seconds and then returns to Paired.
It will not work with companion 1.2 or with DIVE Log 6.0
Pic is of the Bluetooth screen - COM 4 - Com 5 with is the one I should be selecting?
Under Companion 1.2 setting I can select COM4 or Com4(Bluetooth) - Iselect com4(Bluetooth) but it always reverts to just Com4.
New Laptop is ASUS UX501 - Very nice, with updated drivers.
Any Ideas.
Thanks Mark
No Bluetooth connection working on OSTC2
Motardplongeur
Re: No Bluetooth connection working on OSTC2
Hi
See here :
read.php?6,15782
and
read.php?6,15557
you'll find some answers ; as a focus, don't use COM4, make last updates for Win10 and reinstall after Companion.
See here :
read.php?6,15782
and
read.php?6,15557
OSTC #12002 & #11150
Use COM4. Make sure to enable the bluetooth in the OSTC manually before trying to download or update the firmware.
> drivers.
As long as windows update KB3093266 is installed it should work fine with Windows 10 64bit. Post any error messages from the companion here.
> drivers.
Thanks for the help. I will try and report back.
