The new OSTC Sport firmware 10.22 is now available for download: http://www.heinrichsweikamp.com/?id=479&version=de (German) or http://www.heinrichsweikamp.com/?id=479&version=en (English)
Changes since 10.18 (Changes since 10.21):
CHANGE: Logbook now shows end-of-dive date and time for dives made with firmware =10.22
BUGFIX: Text alignment in logbook
NEW: Show actual dive count in logbook list view (If <1000)
BUGFIX: Minor language and text aligment fixes
CHANGE: button hold-down will increase values or move the cursor automatically (again)
BUGFIX: +5min for stopwatch during simulation did not work
BUGFIX: Bluetooth communications issues
NEW: Option to rotate the screen
BUGFIX: BLE timings for MAC issues
BUGFIX: Battery consumption calculation in sleep mode (3,6V battery only)
CHANGE: Custom GF high range increased to 45-95%
BUGFIX: Auto-Brightness clipped to lowest settings in bright sunlight on some devices
OSTC Sport: New Firmware 10.22
Re: OSTC Sport: New Firmware 10.22
Thanks Matthias!
Just purely out of interest, why end-of-dive-time < 10.22 instead of just leaving all with start-of-dive-time?
Because it's stored that way in the logbook "files". Changing the info in the logbook subsequently is not possible. So, older dives are shown with the end-of-dive time. Taking care of "midnight" or "new-year" dives was buggy and error prone. I have removed all this buggy code from the internal logbook now.
(:DRe: OSTC Sport: New Firmware 10.22
[size=large]DANKE!!!(:P)[/size]
[size=small]Jetzt fehlt (mir) nur noch die "lautere" Warnung bei zu schnellem Aufstieg[/size]
My OSTC Sport (new firmware 10.22) indicate Battery Alarm :
Batt:0%
3,2V
My actual battery is a new 3,6 SAFT LS14500, and battery voltage appears to be declining rapidly... (td)
Batt:0%
3,2V
danke!
nach Problemen beim update von 10.20 auf 10.21 funktionierte das update von 10.20 auf 10.22 sofort.
grüsse
grüsse
Continue here: read.php?6,16196
