hwOS Sport: New Firmware 10.53
The new hwOS sport firmware 10.53 is now available for download:
10.53:
BUGFIX: New battery menu was not visible after battery insertion on certain hardware versions
10.52:
NEW: Updates OSTC 2 TR computers to RX-Firmware 1.37
BUGFIX: Fix (another) critical issue with compass routine
With the revised new battery menu this update is strongly recommended for all OSTC plus users but can be installed on other hwOS sport devices, as well. It contains RX firmware 1.37 for all OSTC 2 TR users.
Die neue hwOS sport Firmware 10.53 ist jetzt zum kostenlosen Download verfügbar:
Die folgenden Änderungen wurden eingebaut:
10.53:
BUGFIX: Das "Neue Batterie" menü wurden auf bestimmten Hardwareversionen nicht angezeigt
10.52:
NEU: Aktualisiert OSTC 2 TR auf RX-Firmware 1.37
BUGFIX: Fehler in der Kompass-Routine behoben
Mit dem überarbeiteten "Neue Batterie" Menü ist dieses Update für alle OSTC plus Benutzer dringend angeraten aber es kann natürlich auch auf allen anderen hwOS sport kompatiblen Geräten installiert werden. Es enthält die RX firmware 1.37 für alle OSTC 2 TR Benutzer.
How to install: read.php?6,14509
Re: hwOS Sport: New Firmware 10.53
Updated for 10.53
Maes
Post by Maes »
Hello, I have just update my OSTC sport with the new release.
But My Battery was at 72% juste before the update, now it is 100% !
I think it is a recurrent problem with the update...
Any solution in the future?
Have a nice day.
this "problem" is kind of unsolvable, since we can't look into the battery itself and gauge the chemical-bound power that's still in it. Instead, we measure the voltage and track the amount of charge that was taken out. Even not knowing how much charge the battery still will be able to deliver before it is finished up, we calculate a percentage value from a best trade of both values. On a cold start of the computer, following any firmware update, certain tracking data are inevitably lost. In the formulars used, battery characteristics are build in, which is why it is important to set the correct battery type. Once your used-before battery will drop its voltage past certain tresholds, you may see a step-correction of the percentatge value.
Actually, it's quite an effort that's put into the battery management, as one should think a dive computer is mainly dealing with dive and deco calculations...
SteveGriff
Post by SteveGriff »
Hi Just updated my firmware and now will only give French and Italian. How do I return to English please..
Just realised updated with the wrong firmware file. Oops!.
There are two versions: German/English and Italian/French
make sure to install the "v10_53_DE_EN_ostc_sport_firmware.hex".
Maes
Post by Maes »
Hello Mathias,
I have just received my third OSTC..
I lost my OSTC 2
I have still my OSTC Sport 12085 and
I buy a new one 21357 for my wife.
This new one comes with the firmware 10.53 (English /german).
I discover the menu, use the compas after calibrate it..it was very sensible... but the compass was functionning.
After that I donwloaded the version 10.53 french ... everything okay except the compass... not possible to calibrate it and so the compass is not functionning.
The battery is a Energized Lithium one..that I used before with a lot off problem with the compass..on my 12085. Now I use standard AA Battery without problem.
So is it a problem of firmware ? (ok with EN/GER but not with the French version??) or a problem with the battery type?
Thanks for help
Greatings
Alain
Maes
Post by Maes »
I change the battery and put a "Duracell" Battery...But compass is still not functionning.
I reinstall de 1.53 Fr version but no change...
Any help?
