New 3.15 firmware
New 3.15 firmware
Today, we released the 3.15 stable for the OSTC2 Series (2N/Mk.2/2C).
Changes since 3.00 (Changes since 3.13):
NEW: Allow to set date > 31.12.2020
BUGFIX: Small language fixes
CHANGE: Debug mode disabled (Hard-coded)
NEW: Logbook shows markers with small orange boxes in the profile
BUGFIX: Minor layout fix (Battery warning in divemode)
CHANGE: Color-code battery % display in surface mode (Charge, Full, Normal)
BUGFIX: "First Diluent" and "SP Mode" used same EEPROM location
CHANGE: Battery percent based on ON-Time instead of battery voltage
BUGFIX: Fix licence in German
BUGFIX: Fix minor layout bugs in surface mode
NEW: Auto Setpoint switch function (CC Modes)
BUGFIX: 1st line in logbook was not displayed in rare cases (2C hardware)
BUGFIX: Divetime had unwanted "." behind the minutes
BUGFIX: Entry time in logbook when dive was around midnight
BUGFIX: Show manually set O2 (Gas 6) correctly
BUGFIX: Show dives with >999mins divetime correctly
BUGFIX: Fix color codes 192-223 (Mk.2 and 2N only)
Updating is very easy if you have 1.90 or later and using Windows.
1. Get new bootloader v2: https://heinrichsweikamp.com/service/software
2. Follow the step-by-step instructions: viewtopic.php?f=2&t=4071
Heute haben wir die Version 3.15 stable für die OSTC2 Serie (2N/Mk.2/2C) veröffentlicht.
Das Updaten auf die neue Version ist sehr einfach, wenn bereits 1.90 oder später installiert ist und Windows verwendet wird.
1. Neuen bootloader v2 herunterladen: https://heinrichsweikamp.com/service/software
2. Die einfache Schritt-für-Schritt Anleitung befolgen: viewtopic.php?f=2&t=4071
Best Regards,
Best Regards,
Re: New 3.15 firmware
woohoo! Thank you for your support for our old but reliable OSTC's :D
Vassilis
Thanks for the support. Apparently there are still quite a few old OSTCs out there, regularly accompanying happy owners in their dives.
I certainly am one of them !
OSTC MK2 # 909
OSTC MK2 # 909
svac
Thanks for the support of old OSTC.
This release will resolve my problem of date because for the moment I had reset date to 2011 instead of 2021 ...
Thanks a lot.
Sandrine
OSTC 2N
Thanks a lot.
Sandrine
OSTC 2N
Markus MDDT
Thank You!
My OSTC 2N SN 3888 is working very well and FW update was easy as usual!
PlatinCH
I updated my 2 OSTC 2N and Mk2.
After this update I noticed that the ascent rate displayed was wrong.
She's about 2x too fast.
Do you have a solution?
thanks in advance
thanks in advance
erique
heinrichsweikamp wrote: 19 Jan 2021, 13:03 Today, we released the 3.15 stable for the OSTC2 Series (2N/Mk.2/2C).
I see this as well. During a normal ascent (actual speed verified via the JJCCR Petrel) the OSTC constantly warns with speeds in the 15-17m/min range.PlatinCH wrote: 29 Sep 2021, 14:29 After this update I noticed that the ascent rate displayed was wrong.
@PlatinCH Do you happen to remember what version you were using before upgrading?
@heinrichsweikamp Any idea what could be causing this?
erique
Code: Select all
New in 3.14:
Beta Release
CHANGE: Calculate velocity over a 6sec period
Looks like it will take a 4 seconds mbar change window, but still use the old 2s multiplication constant (== 39)?
Seems incorrect..
This was in fact an unfinished change in the code. So we'll do a 3.16 with the old 2 seconds interval again, which is perfectly fine in terms of averaging and displaying the velocity value to the user.
https://code.heinrichsweikamp.com/publi ... 68f28514e0
Zubar
I’m so pleased to see my 2n is still viable and supported.
Getting back into my diving after a break and good to see all is good with my trusty 2n that has kept me alive over many dives!
Isa87
I have the same problem with the ascent speed display in v3.15
When will the 3.16 firmware be available ?
Continue here: viewtopic.php?t=22482
