ostc not recognized
Iguane
ostc not recognized
Post by Iguane »
I tried to connect my ostc to 4 computers. None of them recognized it. All drivers installed but when I plug the ostc 2n nothing happens. No com created. Help please. I had no problem until now with my computer.
Re: ostc not recognized
And what software have u installed?
What r u trying to do?
Oh and btw. Have a look at the forum. There is heaps of threads that may help u...
Iguane
Post by Iguane »
Diving log. On Windows xp with drivers installed, on Windows 7. No way to connect it.
When you plug in the 2N do you get a orange LED at the bottom/center of the screen?
Have you tried another USB cable?
Have a look at this forum entry:
http://forum.heinrichsweikamp.com/read.php?2,7302,7331#msg-7331
Follow the instructions.
You have to install the FTDI drivers from the FTDI website and then install DivingLog.
You also need to switch on the 2N to download any dives.
Iguane
Post by Iguane »
No idea for the led. I'll check. For the other points I have done it right(drivers FTDI...). I will try with an other USB cable. Thanks.
Iguane
Post by Iguane »
Ok when I plug the ostc I have the orange led. But nothing else happens. No com to be seen.
Did u try another usb cable?
You mean u can't choose a com port in diving log?
Iguane
Post by Iguane »
Yes I tried another USB cable. Not more successfull.
I can choose a com (com3) on divinlog but I have an error message when trying to download. And com3 doesn't exist in the device manager.
Is u r 2N switched on when u try the down load?
divinglog
Post by divinglog »
On Windows 7 the driver should be installed automatically from Windows Update. Make sure that you've switched the OSTC on, then check the COM port list for available ports and try every port.
Iguane
Post by Iguane »
Yes I have done all of this. I really don't underdstand why it doesn't work. Could it be a material failure ? Everything else but connection is working fine.
I tend to think its a problem with the driver , but would of course not exclude the possibility of a HW problem of sorts. It would be great if your unit could be attached to a pc from which the dives of a different unit have been dowloaded.
Question,
- Which diving log software do you use exactly?
- Have you tried OSTC Planner to connect to the OSTC?
- What type of OSTC do you have? 2N, MK2, frog or DR5?
- Do you know anyone else with an OSTC nearby
- What firmware is your OSTC running
when using bootloader V2 or divinglog mine is showing COM3 only with no OSTC connected.
When switching on and connecting my OSTC there's also COM9 available for both applications.
So for my setup COM9 is right.
COM9 will disappear and reappear with disconnecting and reconnecting the switchwed on OSTC.
For your setup the COM-port which did not show before connecting OSTC but is showing after connecting the switched on OSTC is the right one.
Reiner
fishwithlungs
Post by fishwithlungs »
Recently I couldn't resist the temptation and installed Windows8 on spare partition,FTDI drivers installed manually.OSTC does connect,just it sometimes takes 20 min.to create COM port in device manager,and the usb cable doesn't matter(supposing it's not damaged or bad quality),the connection appears or not with all my cables.What helps is GENTLY moving the cable in the OSTC's socket.Then it is only matter of looking in the device manager for newly created serial port and starting the application you use to connect to the OSTC.It has to be connected and turned on BEFORE starting DivingLog or JDeco.
BTW,on my N2 (#4499) there is no visible LED,only in total darkness the faintest hint of the blue one,I haven't managed to see the orange one yet.Slightly annoying when charging the unit.Seems that the LEDs are obscured by the bottom edge of the screen frame.
Good luck,
Richard
Iguane
Post by Iguane »
@sailer : Yes but I have no new serial port created when I plug my ostc. I will try on my personal computer when I come back from vacation. Thanks everybody for your help.
caron_wong
Post by caron_wong »
maybe let me share my experience. I recently lost the cable coming along with my 2N and purchased a micro USB cable. I am also using Win 7 and Dive Log program. I find the cable head (plastic one) is too thick and I had to sharpen it a bit to make the head completely entered into the OSTC 2N connector. I found initially if I didn't insert in completedly, I could get orange LED for charging but no data connection setup.
After I sharpen the cable head by removing some plastic of the USB connector, it is working and the transfer is successful.
Pls. check if the micro USB connector is completely connected to your watch. You will then find the com port immediately.
Hope this help. Cheers!
Caron Wong
OSTC 2N#: 3258
fishwithlungs
@ caron_wong
I gues that is the case with moving the cable in the connector.
Right on!
Followed your advice and now it connects immediately.
Hopefuly it helps @Iguane too.
Richard
Iguane
Post by Iguane »
@caron_wong : thanks for sharing your experience. I will try again this way and also gently move the USB cable if nothing changes.
caron_wong
Welcome, I am also new here.... but I am sure we all are happy HW users!
Caron Wong
OSTC 2N#: 3258
jon lewis
Post by jon lewis »
Hi my ostc 2n will not conect to dive-log 5., I am using windows 7 and followed your previous advice to down load usb drivers have done this and now usb not regognised. The orange light is flashing help
