OSTC3 problem with data and Bluetooth
Marcomet
Post by Marcomet »
Hello. I have OSTC3 SN3090 with software 3.13 Rel.
Unfortunately there is a problem with the date.. I can't change the year above 2024.
I downloaded the latest firmware. but I can't turn on Bluetooth.
Is it possible that my computer does not have this module.?
Kind regards
Marc
Re: OSTC3 problem with data and Bluetooth
Hi Marc,
In 2015 I had an OSTC 3 S/N 3999, it has a USB connection but no Bluetooth. Yours being S/N 3090, I guess it is the same model. So try to update the firmware through UCB.
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
Marcomet
Post by Marcomet »
HI
thanks for the answer.
But here again the problem..
I only found an optical input.
Is that what you wrote about.??
I've never used it. I bought it used - and I don't even have such a cable..
https://mail.google.com/mail/u/0/#inbox ... rojector=1
Marcomet
Post by Marcomet »
optical
optical
Marcomet
Post by Marcomet »
sometimes the closer you have something to your eyes.. the less you see! :D
of course I found it..and I looked at it so many times...
I never opened it.. because there was no need
one more time..thanks for your reply
You got it !
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
Marcomet
Post by Marcomet »
please help..
what am I doing wrong?? can't connect..i've been trying for an hour.
Did you do it??
jb2cool
Post by jb2cool »
How sure are you that this particular USB cable can send data? I’ve seen some that’ll charge things but don’t send data.
Marcomet : are you sure your computer is connected to COM5 and not to another COM port ? Have a look to the Windows peripheral panel.
jb2cool : yes, this USB port is the only way to update the firmware and download dive profiles since there is no Bluetooth on this unit.
Regards.
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
This is one of the cases where we have the exact same questions via email in parallel. So we send an email with some support here already.
@Marcomet
Have you tried anothercable!?
